Old 11-11-2011, 02:05 PM   #1 (permalink)
Question Android phone below 18000
Hi
I am looking for a good android phone and my upper limit is around Rs 18000/-
Requirements:
Android 2.2/2.3
Light Weight
Screen Size: 4"
Options I have seen:
1. Nexus S : I liked this phone, but my badluck I came to know later that it has been discontinued.
2. Samsung Galaxy S: I like this phone, only drawback is that it does not have a camera LED flash.(Which is very helpful at times as a torch)
3. LG Optimus Black : I like this phone, it has every thing that I am looking for, but it comes from LG. I am not able to rely on LG as a brand.
Please help me out and let me know if there are any other options that I can look for.
abhishek12 is offline   Reply With Quote
Old 11-11-2011, 03:31 PM   #2 (permalink)
bloody hell mate!!!!
maddy1205's Avatar
Default Re: Android phone below 18000
i would suggest Motorola defy or even better the newly launched defy+...although i feel that defy+ is bit overpriced....
maddy1205 is offline   Reply With Quote
Old 11-11-2011, 04:08 PM   #3 (permalink)
defy+ is really overpriced. optimus black is a half baked mobile. excellent hardware but still stuck in froyo & is equally buggy. heard about bad battery backup. gingerbread coming nov end but it most likely will be 2X more buggy. go for it only if you will try custom rom. lastly try Xperia V or Ray.
Sam is offline   Reply With Quote
Old 11-11-2011, 04:19 PM   #4 (permalink)
I checked at gsmarena both Motorola Defy and Xperia Arc does not have a secondary camera, which I feel is a good feature to have.
Old 11-11-2011, 04:34 PM   #5 (permalink)
Dust in the Wind
Skud's Avatar
Check Sony Ericsson Xperia neo V.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline   Reply With Quote
Old 11-11-2011, 04:59 PM   #6 (permalink)
arc cost 23k or more.
Old 11-11-2011, 05:03 PM   #7 (permalink)
clmlbx's Avatar
+1 for Neo V, best in that range
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline   Reply With Quote
Old 11-11-2011, 06:35 PM   #8 (permalink)
vulpine's Avatar
Get nexus S if you can find it! try ebay...
or galaxy S would meet your requirements.
Really? Would you want to ignore Galaxy S just that it doesn't have a torch light?? :O
c'mon... go for it! you wont miss torch light.... you can use screen for that...
go for galaxy S plus (if galaxy S is not available)
Dell XPS 15 Full HD | HTC Desire S | iPod Touch 32GB 4th Gen | Sennheiser CX180 | and a few more
vulpine is offline   Reply With Quote
Old 11-11-2011, 08:16 PM   #9 (permalink)
Dust in the Wind
Skud's Avatar
Galaxy S plus will cost at least 21k. Otherwise, it is a good option.
Gaming Rig:
HTPC Rig:
Old 11-11-2011, 11:19 PM   #10 (permalink)
I would have settled for Galaxy S, but I feel the camera LED is useful for me, as I do use this at many instances in my current phone. (I understand many might not give much weight-age to this.)
And is Sony Ericsson a good buy, what about updates, do they provide regular updates.
I somehow only feel like choosing between HTC and Samsung
Old 11-11-2011, 11:30 PM   #11 (permalink)
Explorer
aroraanant's Avatar
If u can extend ur budget a lil bit then u can buy HTC Desire S,I saw yesterday that it was priced for approx 19.3k on sulekha.It is far better than Optimus black and SGS.Or if u prefer not to buy it from sulekha u can get it from letsbuy for 20-20.3k
Extending ur budget further more u can get HTC Incredible S from Sulekha at 21k
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
Old 12-11-2011, 12:54 AM   #12 (permalink)
Dev
dreatica's Avatar
If you can compromise on the camera flash SGS+ is VFM ph within 20k bracket since you requirement includes 4' screen and super amoled display is just awesome to worth spending 2k extra
dreatica is offline   Reply With Quote
Old 12-11-2011, 08:24 PM   #13 (permalink)
went it in to some shops inquiring about HTC Desire S . To be frank shop keepers are half hearted in their effort to sell a HTC device .
Plus Desire S is stuck at 22k for quite a while now . Needs a Price cut .
Off topic but SGS Plus was available at 20k . But being a third revision to a model i did expected a flash this time . Samsung(Flash Less) going the Nokia Way now (Fixed Focus Cams).
pentiumlover is offline   Reply With Quote
Old 12-11-2011, 10:07 PM   #14 (permalink)
desire s is way too much overpriced..with similar specs go for either defy+ or the neo v..depends on ur personal preference as both of them have a few exciting features...
sharang_3 is offline   Reply With Quote
Old 12-11-2011, 10:08 PM   #15 (permalink)
Explorer
aroraanant's Avatar
U can get it online from letsbuy or sulekha or flipkart...
May be it is because they are getting less profit in HTC.But one thing I would tell u.I m having 3 phones in my home of HTC and they are awesome and I m fully satisfied and also I haven't experienced any problem in any of the phone....
Old 12-11-2011, 10:08 PM   #16 (permalink)
p.s. you can get both defy+ and neo v for 16k..if you use coupons on shopping sites..
Old 14-11-2011, 10:55 AM   #17 (permalink)
127.0.0.1
mitraark's Avatar
Can anyone mention the difference between Galaxy S and Galaxy S Plus ?? Including current price ???
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 14-11-2011, 07:28 PM   #18 (permalink)
Will Power
TheLetterD's Avatar
Have you Checked out the Xperia Play? AKA The PSP Phone... U can get it for 19.5 K if you bargain a lot from Local Vendors....
Preferably look for phones which would get ICS 4
And as far as I know almost all phones from Sony Erricson (All the new ones + Some old ones like the Play and Arc) Are getting ICS!
Mark my words, Soon after the Zombie Apocalypse, The Apes WILL take over! :hyper:
Follow me @ http://twitter.com/ThaLetterD
TheLetterD is offline   Reply With Quote
