Old 26-10-2011, 02:38 PM   #1 (permalink)
Default Guide me to Transfer my CONTACT from Nokia E7(backup) to Samsung Galaxy S i9000
experts,
i was a big fan of nokia till last few months. was used Nokia E7, lastly, taht was got missed in an Auto Rikshaw. (that was an old story..!)
well, i brought Samsung Galaxy S i9000.
i am having my CONTACT backup in my lappy which i made that from Nokia E7-00.
was there any way to get copied in this Anroid?? any app available??
hardly waiting for your reply
lovingly
mobileman
mobileman is offline   Reply With Quote
Old 26-10-2011, 03:24 PM   #2 (permalink)
socrates's Avatar
Default Re: Guide me to Transfer my CONTACT from Nokia E7(backup) to Samsung Galaxy S i9000
Have you made this backup in the PC Suite/Ovi Suite file format or did you take it in Outlook. If its in Outlook then you can import it into your Samsung thru Kies or even MyPhoneExplorer http://www.fjsoft.at/en/ but if its in the proprietary format of Nokia/Ovi Suite then it might not be so straight forward.
be what you are
and say what you feel
bcoz those who mind, don't matter
and those who matter, don't mind !!
socrates is offline   Reply With Quote
Old 26-10-2011, 03:53 PM   #3 (permalink)
Originally Posted by socrates View Post
Have you made this backup in the PC Suite/Ovi Suite file format or did you take it in Outlook. If its in Outlook then you can import it into your Samsung thru Kies or even MyPhoneExplorer FJ Software Development but if its in the proprietary format of Nokia/Ovi Suite then it might not be so straight forward.
Dear,
yes, i saved backup in Nokia/Ovi Suit.
then it seems, first i have to export this to Outlook and to try with KTES.
well, now thinking the way to export from Ovi to Outlook.
waiting
Old 26-10-2011, 04:10 PM   #4 (permalink)
iDota
Sarath's Avatar
Just check if it ends with .vcf in the end for the Nokia back up. I did it many times but never checked for the extension.
If it is in vcf format, just transfer it to your phone memory (card) and use the "import contacts" feature in "contacts"
Online Shopping guide - PART IIIPS3™ master guide
Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180 | | | Article/Discussion: PS3™ vs PC
Sarath is offline   Reply With Quote
Old 26-10-2011, 07:22 PM   #5 (permalink)
socrates's Avatar
When a 'Backup' is taken thru Ovi I think the file extension is .nbu I presume you have already got rid of your E7 I can think of only transferring the old Ovi contacts into a Nokia which has that capacity then sync with Outlook (Sync is the Nokia terminology) then use Kies or MyPhoneExplorer http://www.fjsoft.at/en/ to bring them into your current phone.
be what you are
Old 26-10-2011, 07:32 PM   #6 (permalink)
aniket.cain's Avatar
If you took a backup using Ovi suite, it will most probably be in the format .nbu. If it is, download NBU Explorer, it is a very small program, and it will export all the contacts in vcf format. Then you can put them in the memory card, and import in your Galaxy S.
Here is the link for the same:
NBUExplorer
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 26-10-2011, 07:48 PM   #7 (permalink)
socrates's Avatar
Yes that looks like as if will do the job Thanks I will bookmark it. I as a rule ALWAYS keepa copy of my contacts in Outlook as well as (currently) MyPhoneExplorer or SE PC Suite. If I change the phone make then I can ALWAYS use the contents in Outlook.
be what you are
