I have SoundMagic PL21 and use them with large eartips supplied with it.
Problem is that they sometimes slips too easily from my earcanal, (XL ones dont fit in..
So was considering for some foamtips.. (of large size i think or you can suggest..
I found these two, but not sure if they will fit into the PL21's.. (Also seems to be quite expensive
Soundmagic Foam Tips [ 3 Pair Medium Size ].
Soundmagic Foam Tips [ Pair Each - Small , Medium and Large ].
Also pls suggest some other foamtips compatible with PL21's.. (Preferably if SoundMagics provide them..)
