29-08-2005, 03:37 PM
how to connect Nokia 1100 to PC
Can somebody tell me how to connect nokia 1100 to pc.
and what else can be done with phone and what are the precautions should be taken while doing this.
thanks
varun
29-08-2005, 04:02 PM
Rebooting
hai mate... well come to the forum....
well at the service center they do use some thing to connect the phone for servicing.... but with normal computer & data cable... hmm i dont think that u can connect it...
rebooting
ChotoCheeta.com
29-08-2005, 04:05 PM
MVP in VC++
Yup even i dont think that Data Cable is supported by Nokia 1100
29-08-2005, 04:17 PM
prob sloved!!!!!!!!!
there is a special cable comes to connect phones like 1100,1108,3310........... ,this cable is diff frm other data cables and is not readily available in market, if u got the cable just remove the battery frm the backside n connect the cable to urs flash mem. using this u can edit urs picture messages etc.........
29-08-2005, 04:19 PM
Rebooting
pls explain in details....
rebooting
ChotoCheeta.com
29-08-2005, 04:32 PM
i dont thin there is any special data cable for that
is there any ?
29-08-2005, 05:06 PM
YES. u r talkin on an interestin' topic which everybody 'd like to know in details.
do share it with us.
29-08-2005, 08:27 PM
I think these types of cable are only available with the service centre people.
\" I Do not like to repeat success , i like to move on to other things \"
29-08-2005, 09:05 PM
Another Brick in the Wall
No, I dont think we can connect to PC. But I am not sure.
Moved here
29-08-2005, 10:46 PM
Microsoft MVP
Yes!
U can connect these phones to pc using special kind data cables.
I too hv one such cable for my Nokia 2100.
Its a cable which u hv to fit between Battery and mobile.
Actually first u remove battery from mobile, fit the battery in that data cable, fit that part of cable in which the battery is set into the phone.
U can see there is some pins inside the phone under the battery, thats the exact place where the front part of data cable is connected.
And u can use s/w like LOGO MANAGER and many other available on net for transfering ringtones, logos, changing security code, etc...
29-08-2005, 11:17 PM
Yes, you can connect these phones.
I do have a cable for Nokia 3310, and i used it a long time ago. Such cables are available for 1100 too.
You need to remove the battery, place one end of the cable to the phone and place the battery over it. and it just works like any other datacable, u can edit ur ringtones, picture and text messages etc
Sometime you'll think you understand everything
...Then you'll regain consciousness
29-08-2005, 11:20 PM
It looks like this
29-08-2005, 11:35 PM
Microsoft MVP
Very true.
And mine cable for 2100 is a serial one...
I got it in 500 /- with a CD full of many ringtones and LOGO MANAGER s/w.
02-09-2005, 02:37 PM
Wire muncher!
this type of connection is called as F-Bus connection. you can do stuff like backup ur phonebook, change op logos, transfer ringers, backup messages, upload pic msgs etc. the usb connector cable is available for about rs.350 and the serial one for about rs.150. you can get these easily in electronic market of ur local city. you wont get an original nokia tho!
02-09-2005, 08:06 PM
Yes,
Cable for 2100, 3310 are available easily.. 500 is heck expensive.. can get u cheaper..
1100 Was also available but now it is extremly hard to find..
I\'M BACK
27-09-2005, 05:49 PM
thanks to all who did post for this post.
all your suggestions are great.
but mine Nokia 1100 is stolen.
so i will buy another one.
thanks
varun
28-09-2005, 10:08 PM
I think such cables r called dku or dk5 cables.
Not very sure....
29-09-2005, 12:01 AM
no, dku-5 and dku-2 cables are meant to connect phones with pop port.
Have a look here
DKU-5
DKU-2
