Old 17-09-2011, 08:20 PM   #1 (permalink)
iDota
Sarath's Avatar
Default Blocking unwanted calls (not marketing calls)
I want to know if there is any software that can block calls from a particular number.
This is to block a regular number and not the ones that come under the purview of DND etc.
Have been receiving pesky calls from a certain number. Reporting the number to the Airtel CC wont help in case they change the number nor am I aware if such a feature exists.
Device:
Oh a little correction here. Its Symbian S30 or S40. Its either on, which one I am not sure. Its not the S60 for sure. Here is the phone
Symbian S60 v3 (Nokia C7 or N8)
This is very important. Thanks in advance.
Online Shopping guide - PART IIIPS3™ master guide
Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180 | | | Article/Discussion: PS3™ vs PC
Sarath is offline   Reply With Quote
Old 17-09-2011, 08:26 PM   #2 (permalink)
eagle_y2j's Avatar
Default Re: Blocking unwanted calls (not marketing calls)
yes lots of call blocking software are there in market..
Registered LINUX USER #438929
eagle_y2j is offline   Reply With Quote
Old 17-09-2011, 08:58 PM   #3 (permalink)
iDota
Sarath's Avatar
I am aware that there are plenty offering. Google pretty much answers all queries. I want something from anyones first hand experience. I basically want someone to recommend a good SW that they have used or are using.
Now since S40 doesn't allow for background apps to run, it suggests that no such SW/ app can run successfully. I hope my assumptions are wrong.
Old 17-09-2011, 10:38 PM   #4 (permalink)
Peak Oil is real!
AndroidFan's Avatar
I have used a Nokia 6275i S40 based device in the past. It had an option to block upto 10 numbers... A blocklist of some kind... You might find it in Settings, Call Options... I don't remember perfectly because I don't have that phone right now...
So, I am sure your phone has that option too... Don't need any apps for that... Nokia phones are good...
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 18-09-2011, 03:51 AM   #5 (permalink)
Off for a while.
dashing.sujay's Avatar
These softs just cut the calls straight away without notifying you (the other person would listen busy thing). And i hate this, AFAIK no soft provides you any way to make other person unaware of your ignorance. I mean you cant change network dependent msgs, such as after call cut, it says the user you are calling is busy atm.
Sony Vaio CB35-> i5-2430M | 6630M | 4GB | 1080p | Backlit Keyboard
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Drop Box: Get 500MB free
dashing.sujay is online now   Reply With Quote
Old 18-09-2011, 09:48 AM   #6 (permalink)
Peak Oil is real!
AndroidFan's Avatar
There is an app in the android market called Mr Number.
I use it to block calls and messages. It had an option "pick up and hang"
--- George Carlin
Old 18-09-2011, 03:08 PM   #7 (permalink)
andcha's Avatar
Try Airtel Call Manager. It blocks number of your choice from operator end. I think this service is chargeable @ Rs. 15 p.m
cm.airtel.in
andcha is offline   Reply With Quote
