Old 15-09-2011, 08:25 PM   #1 (permalink)
Harivel's Avatar
Question How i unpack/unzip .apk files??
Plszz Help Me out!!
How i unpack apk files to view the files??
Harivel is offline   Reply With Quote
Old 15-09-2011, 08:59 PM   #2 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: How i unpack/unzip .apk files??
Even if you do extract it you won't get the actual code. You will a smaller format made by the compiler I believe. If such a case is enough then I believe apktool might work.
You aren't asking how to install an apk file are you ?
FilledVoid is offline   Reply With Quote
