Old 14-09-2011, 07:22 PM   #1 (permalink)
Angry How to use apps without using Mobile Network or WiFi (Via PC)?
Guys, Just as the heading suggests, can u please tell me how i can use android apps without using WiFi (Dont have it) or Mobile Network(Dont want to use it).
How should I get an app from the android market or any other good site onto my pc and then onto my SGS2??
Waiting for your help. thanks a million
rishabh.archi.singh is offline   Reply With Quote
Old 14-09-2011, 08:04 PM   #2 (permalink)
Default Re: How to use apps without using Mobile Network or WiFi (Via PC)?
The links here have a couple of methods that will do the trick -
How to install android applications from computer - Android Forums
and
How to install android applications from computer‎ without astro manager on the phone ? - Yahoo! Answers
Be sure to enable "unknown sources" on yous phone from settings menu
Old 14-09-2011, 11:23 PM   #3 (permalink)
The sites arent that nice. But thanks nonetheless!
Can u pls tell me some other goood sites?
Old 16-09-2011, 02:17 PM   #4 (permalink)
Basically you need to find an apk file for that application which you need to install. Then transfer that to your mobile and install.
s_holmes is offline   Reply With Quote
Old 17-09-2011, 03:18 PM   #5 (permalink)
The Devil
blackpearl's Avatar
Search for the app name followed by apk on 4shared.com
For example, "astro manager apk"
blackpearl is offline   Reply With Quote
Old 23-09-2011, 01:32 PM   #6 (permalink)
Thanks alot guys. 4shared is great So are the sites. Im happy VERY
