Old 09-09-2011, 06:46 AM   #1 (permalink)
soyab0007's Avatar
Default phone under 1000rs
looking for a basic phone for my office
i.am looking for max msg storage capacity and fm
budget Rs1000
I don't want another Cinderella story. I don't even want a Twilight story. All I want is 'you n me' together! Our own story with our own "happy ending"
soyab0007 is offline   Reply With Quote
Old 09-09-2011, 10:10 AM   #2 (permalink)
Default Re: phone under 1000rs
how about this? Samsung Guru E1085T
Old 09-09-2011, 11:08 AM   #3 (permalink)
Dev
dreatica's Avatar
budget Rs1000
If you can increase your budget to 1.5k, you can get Nokia X1-01 which supports 16gb memory/FM radio and loud music. Message capacity would be 500 though but its VFM.
dreatica is offline   Reply With Quote
Old 09-09-2011, 01:25 PM   #4 (permalink)
aniket.cain's Avatar
+1 for X1-01. I bought one just a few days ago for some extra sims lying around, and the sound is really loud and clear, both on speakers, and when plugging in earphones. Totally VFM.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 09-09-2011, 02:46 PM   #5 (permalink)
soyab0007's Avatar
daily i get 10-15msgs and i do not want to delete that msgs
any other phone with atleast 1000msg storage capacity..
Old 09-09-2011, 03:17 PM   #6 (permalink)
in the kaya
gmg9's Avatar
any ph. within 2000/- which has gprs(edge)+fm+java support etc..
Device: LG OptimusOne P500
ROM: mik CM7.1-RC1 6.5.7b
Kernel: ffk v19.4
CPU OC: 480/748 smartass-v2
CR: Amon_Ra Thunderg 2.2.1
Kolkata Android Users Group
KOLKATA ANDROID MeetUp 2011
gmg9 is offline   Reply With Quote
Old 09-09-2011, 06:36 PM   #7 (permalink)
samudragupta's Avatar
you should increase your budget a bit....you should consider the MicroMax X111 for 1200/-
it also has 32gb extendable memory
samudragupta is online now   Reply With Quote
