Old 27-08-2005, 12:02 PM   #1 (permalink)
tweety_bird_bunny's Avatar
Default how to create mobile wallpapers?
i've nok 6600...i sent some wallpapers to my pc thru bluetooth...if i send the original file the wallpaper is displayed..but if i send the resized image using a software ,it is not opened,,however on my pc i can c it....
what is wrong???software???then suggest one..
tweety_bird_bunny is offline
Old 27-08-2005, 02:46 PM   #2 (permalink)
String Phreak
mediator's Avatar
Nothing wrong, I presume u r using nokia software!
There u have to use wallpaper after resizing!
mediator is offline
Old 27-08-2005, 02:47 PM   #3 (permalink)
Paneer is offline
Old 27-08-2005, 04:41 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
huh !
paneer copied mediator ?
1st time i m seein this...
well, i think the resizer softie is corroded...
do u get to see the pic after u resize it ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 27-08-2005, 08:41 PM   #5 (permalink)
expertno.1's Avatar
how could it be jsut same to same in an interval of 1 minute ?
u sent from mobile to pc and asking that
[quote]ut if i send the resized image using a software ,it is not opened,,however on my pc i can c it....
[quote]
could not understand
expertno.1 is offline
Old 28-08-2005, 12:56 AM   #6 (permalink)
Use " Image Resizer " to resize them and then copy to your phone.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 28-08-2005, 07:30 AM   #7 (permalink)
expertno.1's Avatar
just edit the image using photoshop and then resizd it and then save as a new file
it will work
Old 29-08-2005, 12:38 PM   #8 (permalink)
well it means when he opens it in pc it can be previewed but when it comes to opening in mobile it says like "can't open file"
it normally happens when there is a corrup data transfer. just take it easy and transfer the file to ur mobile back. and Nokia resizing software is quite pretty to use. u dont even need to use photoshop.
this problem could have been solved faster, if posted in mobile monsters section.
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 29-08-2005, 03:47 PM   #9 (permalink)
expertno.1's Avatar
dude he is telling that
"i sent some wallpapers to my pc thru bluetooth"
and again telling that he can preview in computer and not in mobile
then how he sent the file using the mobile ?
Old 05-09-2005, 07:26 AM   #10 (permalink)
use nokia pcsuite for 6600 and then resize images in it and then send it via bluetooth...
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 05-09-2005, 02:45 PM   #11 (permalink)
expertno.1's Avatar
nokia pc suite software is for pc (to use the mobile)and not for nokia mobiles(not present in mobile_
