Old 03-09-2011, 03:06 PM   #1 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
Default Help;;Nokia PC suite faliing to Restore contacts!!
hello,
I am using Nokia E63,,yesterday i backed up my phone contacts, calendars through Nokia PC suite to my laptop. Then i did a hard reset of my fone as it was running very sluggishly. Then i tried to restore the contacts and calendar through the Nokia PC suite. But the progress in the PC suite gets stucked at 59% for over 2 hrs and doesnt move beyond that. I tried this many times.
Plz help me. I am in dire need to restore my contacts and calendar.
Thanks in advance.
|| Beauty is to the Mind what Food is to the Body ||
panacea_amc is offline   Reply With Quote
Old 03-09-2011, 04:39 PM   #2 (permalink)
Spiritual Eternity
sameerwni's Avatar
Default Re: Help;;Nokia PC suite faliing to Restore contacts!!
Uninstall Nokia Connectivity Cable Driver and then install it back.
Then give a try!
sameerwni is offline   Reply With Quote
Old 03-09-2011, 06:16 PM   #3 (permalink)
i don't know if there is any such option in PC Suite but try to sync the contacts with Nokia Server from PC Suite. uninstall PC Suite. get Ovi Suite & try again. do this only if the above mentioned way fails.
