been very happpy with nokia 5800xm. need to replace it with another. so help out. i have lost phones recently around 4 in last one year so thinking of the cheapest option that is between rs0 to rs 23000.
mainly used the 5800 for and loved the following features
1. didnt hang up
2. battery life good
3. camera the best required min is good quality 3mp. the more the merrier
4. input method to enter contacts
5. web browsing fast to find information on the go
6. didnt listen much to music but when i do i need good sound
7. if i can find one which can edit text it will be good as in msword
8. if some applications are open like camera etc it shouldnt become slow
9. mainly used nokia always
10. sticky notes
11. customizable front screen
12. can i get some refund if i loose it again
fast help in form of reply required
thanks in advance
pl suggest all range not just higher end
also filing this as saw this later
1. Budget? Rs 0 to 23000
2. Display type and size? ANY but not interested in nokia e71 kind phones
3. Form Factor? bar, slider, flip? ANY
4. Preferred choice of brand? mainly been using nokia but ANY will work
5. Preferred input method (QWERTY, touchscreen, numpad, touch-n-type). touchscreen
6. What camera option you want? Please specify need for flash, autofocus, front facing camera.MIN 3 MP, IF MORE IT IS ACCEPTABLE
7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc). ANY have used imate before
8. Preferred connectivity options (3G, Wifi etc)Please specify clearly. would want it ot be 3G compatible
9. Preferred applications (Flash, Swype, GPS, etc)?
10. Primary use of handset (multimedia, camera, mails, internet, gaming etc)? CAMERA, OCC MAILS, INTERNET YES
11. Any specific mobile phones in consideration? AGAIN NOKIA 5800
12. Any other info that you want to share. PHONE SHOUDNT HANG UP ON ME, BATTERY LIFE GOOD, INPUT METHOD HANDWRITING, GOOD SOUND QUALITY, TEXT EDITOR WUD BE GOOD,customizable front screen
THANKX
someone admin etc reply plz
