Old 11-08-2011, 04:48 PM   #1 (permalink)
Exclamation Samsung Galaxy 551 / GT i5510
Hi guyz,
I'm a developer currently in PHP AJAX. Let's leave that part now. I need a solution for my mobile. For past few months I started to use Android Phone Samsung Galaxy GTi5510. I love to use apps given by Google. But the problem is my Phone Storage is filled now. So, I couldn't update or install any new Apps though I have 7GB free space in my SD Card. Is there any way to move all my installed apps from my Phone Storage to my SD Card? Or Is there any way to install Apps in SD cards here after? A good solution will be gratefull! I'm totally ...... Is there anyone to help ME?
vino.gcs is offline   Reply With Quote
Old 11-08-2011, 05:51 PM   #2 (permalink)
Default re: Samsung Galaxy 551 / GT i5510
your mobile runs on Android 2.2, right? then go to setting>application>Manage applications> then select the apps one by one and move it to sd card. or use app2sd from market.
Old 12-08-2011, 06:32 PM   #3 (permalink)
I luv Digit
you can try apps2sd or movesd from the Android Market or use the method in this link to permanently make the memory card, the default install location.
Androinica » How to Install Apps to the SD Card by Default on Android 2.2 Froyo
hotshot05 is offline   Reply With Quote
