Old 11-08-2011, 04:20 PM   #1 (permalink)
Simply.. Evolution !!
TheMost's Avatar
Default N95 8GB - Downgraded performance
I Bought a N95 8GB 3 yrs back and still have that for me
The prob is it is getting slower and slower day by day ...
How to bring that to condition ..
I Am using only its 8GB .... Didn't make any modifications ....
Should i update ??? How do i do that ???
Via Nseries PC suite or Nokia PC suite ??
| Core2Quad Q6600 @ 2.40GHz, 4GB RAM |GeForce GTX 260 |
:???: BUSY BEEE :?
TheMost is offline   Reply With Quote
Old 11-08-2011, 04:45 PM   #2 (permalink)
Default Re: N95 8GB - Downgraded performance
try ovi suite if it supports. it has an option of reinstalling the OS. same option should be there in pc suite also.
Old 11-08-2011, 05:04 PM   #3 (permalink)
iDota
Sarath's Avatar
How much of the internal memory is free?
Online Shopping guide - PART IIIPS3™ master guide
Gaming:♦ PS3 ♣ i5|HD6970 Gaming RIG | Dell U2311H review iΡod & iPhone 4 ♥ Xperia™ Arc review
Audio gear: Logitech Z623 | Klipsch X10 | Siberia V1 | M1 | M2 | CX180 | | | Article/Discussion: PS3™ vs PC
Sarath is offline   Reply With Quote
Old 11-08-2011, 05:07 PM   #4 (permalink)
TheMost's Avatar
^ 1.7 gb
:???: BUSY BEEE :?
Old 11-08-2011, 05:14 PM   #5 (permalink)
iDota
Sarath's Avatar
When you go to the file manager how many memories does it show?
I am asking coz I remeber using a nokia which had 250MB internal memory although it had 8GB built in but counted as external memory.
Old 11-08-2011, 05:17 PM   #6 (permalink)
TheMost's Avatar
^ ya i have two Drives Kind'a !
Ovi supports -- trying updates
:???: BUSY BEEE :?
Old 11-08-2011, 06:47 PM   #7 (permalink)
Techno Freak
i Know this is the issue to almost all smart phone and PC's (windows) too....
Reason is as we continue to use the PC and Phones for years and years, the Internal memory gets filled with apps and there created files and others.
i suggest you to Reset your phone (Complete Reset *#7370#).
this Reset deletes all the files in Internal mem and Other parts (excluding Card memory)
BEWARE: this Reset will Delete your Contacts, Messages, Docs ,calendar and notes. just take back up of all the data Via Nokia ovi suite .
(it is just like Windows , as we format it and reinstall it, and it is New and brilliant after then)
suyash_123 is offline   Reply With Quote
Old 12-08-2011, 10:05 AM   #8 (permalink)
TheMost's Avatar
^ I'll try - Now backing up...
UPDATE :
Hey guys i have updated my model to a newer version and had some new apps and now its faster than before ... But yes a 1 second or 1.5-2 second lag ....
Will try hard reset too and let you know .
:???: BUSY BEEE :?
Old 12-08-2011, 11:29 AM   #9 (permalink)
Fullbring
Zangetsu's Avatar
thats a soft reset...
@TheMost: Do a Hard Reset....
press dial button(green) + * + 3 + switchoff button
all above 4 simultaneously & phone will restart with as new as new phone
Old 12-08-2011, 05:28 PM   #10 (permalink)
Originally Posted by TheMost View Post
UPDATE :
as expected
don't know about Symbian mobiles much (never done a complete reinstall of the OS) but a hard reset is a must for most Android mobiles if mobile OS is updated.
