Old 10-08-2011, 07:57 AM   #1 (permalink)
deepak_ds's Avatar
Default Nokia C6-00
I own a Nokia C6-00. It has a typical problem. I cannot edit suite settings..! What should I do?
And my phone hangs a lot if I install more and more applications.
Any suggestion to keep the phone working bit responsive?
deepak_ds is offline   Reply With Quote
Old 10-08-2011, 08:56 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Nokia C6-00
phone hanging when you install more and moe apps is usual. to fix it, see if you can get a higher speed SD card and install apps to that sd card. And do a reset of everything, that might work.
desiibond is offline   Reply With Quote
Old 10-08-2011, 11:33 AM   #3 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Maybe there might be some good custom ROMs for the Nokia C6-00... I find custom ROMs for Nokia 52xx series all the time in forums... They really work...
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 10-08-2011, 12:10 PM   #4 (permalink)
Hi i have used C6 earlier. I suggest you get a faster memory card as it solved all problems for me.
tronman10 is offline   Reply With Quote
Old 12-08-2011, 07:15 AM   #5 (permalink)
deepak_ds's Avatar
Suggest me a fast memory card.
Old 12-08-2011, 07:34 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
something like this: Flipkart.com: Transcend Memory Card 8 GB MicroSDHC 8GB Class 10: Memory Card
Old 12-08-2011, 07:59 AM   #7 (permalink)
deepak_ds's Avatar
Thanks
