Old 24-08-2005, 12:53 PM   #1 (permalink)
karthik55859's Avatar
Default Help? cant connect nokia 3100
hi
I have nokia 3100, a DKU-5 cable competable with 3100 when i connect one end of the cable to mobile a message pops up in mobile screen as data enhancement connected, but i cannot install it in my pc....
i have 1st installed DKU-5 cable drivers, and Nokia PC Suite, and also installed nokia modem drivers,,still i dont get my mobile recognised by my pc when i use get connected it stops where it says to connect the cable i also changed the connection type to dku 5 cable in the Manage connections still it wont get recognised so plz can any one tell me wats wrong??? i am fed of with the problem plz help
karthik55859 is offline
Old 24-08-2005, 01:23 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
First Nokia 3100 doesnt hv Modem, so no need to install modem drivers.
And about the connection problem, goto Manage Connections, select Serial Cable (DKU-5, CA-42) and click on Configure button and select the right port in the drop-down list. (It should be like Prolific USB-to-Serial Comm Port).
It should work now.
And make sure no other mobile s/w is running in background by opening Task manager.
PS: PC Suite latest version 6.6 is gr8, it automatically detect the mobile phone in a few seconds...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
