Old 06-08-2011, 11:16 PM   #1 (permalink)
dharmil007's Avatar
Default Bought Nexus S..... Queries
Hey Hello everyOne
ThanK u Ppl. for u such WonderFul suggestions.
based on ur Suggestions i Suggested my Friend to go for Nexus S.
My friend has bought Nexus S & its such a wonderFul device i m literally hooked to it.
i Myself m Thinking of buying one
I have some question regarding this nexuS s.
1. What is the difference between kernel & mods {eg. cyanogen, oxygen, etc}
2. i Have heard from someOne that out of 512mb Ram only 200mb is useFul rest is used by GPU.But it has a dedicated GPU, so why its using Phones RAM ??
3. Browser is lagging is there a solution for this ??
4. Do rooting & installing diff. mods/kernel void warranty ? & can this warranty be got back after we install stock ROM ?
5. iS 720p recording possible through any Custom ROMS ?
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
dharmil007 is offline   Reply With Quote
Old 06-08-2011, 11:33 PM   #2 (permalink)
Default re: Bought Nexus S..... Queries
1. kernel . mod = a rom derived from official rom or CAF (code aurora files) or Cyanogen ROM (Cyanogen is a a team that makes freshly built rom for some specific mobiles).
2. never heard anything like that. but usually, of 512Mb, around 350Mb should be free.
3. lagging all the time or when using some flash heavy website?
4. yes rooting voids warranty & restoring the mobile to stock state will bring back warranty.
5. yes, maybe. look here
Old 07-08-2011, 12:02 AM   #3 (permalink)
Mozilla Rep
sygeek's Avatar
  1. Kernel vs. Rom
  2. Nothing like that, GPU doesn't use the RAM.* Neither is there a limitation 200MB or whatsoever. Who told you this stuff?
  3. Heavy flash-based sites are bound to lag depending on the way they're coded. Give me an example of such a site that lags for you. Also, I'd suggest you go for a 3rd party browser like Opera/Firefox and see if it can handle those sites better.
  4. Technically, rooting doesn't void your warranty, unlocking the bootloader does. Practically, most of the time, this process involves unlocking the bootloader, so, in simple words, YES, rooting does void your warranty. And it is reversible depending upon your phone/custom ROM.
  5. It maybe possible, but as of yet, no custom ROM has achieved this.
*Edit: This a personal assumption, correct me if I'm wrong
sygeek is online now   Reply With Quote
Old 07-08-2011, 12:06 AM   #4 (permalink)
dharmil007's Avatar
Originally Posted by sygeek View Post
  1. Nothing like that, GPU doesn't use the RAM. Neither is there a limitation 200MB or whatsoever. Who told you this stuff?*
*[Edit: This a personal assumption here, correct me if I'm wrong]
i Have seen this on XDA Forum, many ppl are complaining about this.
So i Thought that someone here may have an Answer to this
Old 07-08-2011, 01:00 AM   #5 (permalink)
Soumik's Avatar
1. already answered.
2. As far as i know, GPU does reserve a certain amount of system RAM for itself. Thats the reason why Galaxy S/Nexus has such a low amount of available RAM, while Galaxy SL has a larger amount of free RAM. Better the GPU, more is the RAM allocated to it. There is no dedicated GPU concept in phones like in computers. Its the combined chipset, it doesnt have any memory. So, a certain amount will be reserved for it to use from the system RAM. Or so i guess.
3. Not sure y its lagging. Try Opera Mini. Or if u have wifi, Dolphin HD broser.
4. As already stated.
5. Yes its possible. For now, its under test and available as a Mod. Check this : XDA Forums
Soumik is online now   Reply With Quote
Old 08-08-2011, 12:05 PM   #6 (permalink)
Bad to the bone
amitabhishek's Avatar
A: Kernel is the core of the OS (mods). It directly speaks to the hardware. Every mod comes with its own kernel. Same kernel can power different mods (for same device).
A: You are right. The RAM is shared with GPU it's not dedicated.
A: Android browser is the best in business, nothing beats it, check the speed of the connection.
A: Yes it voids the warranty. Unrooting is far more difficult than rooting. But it is possible. To revert to warranty & receive OTAs from Google you will have to revert to factory ROM.
5. Is 720p recording possible through any Custom ROMS ??
A: No
Twitter: @amitabhishek
amitabhishek is offline   Reply With Quote
Old 09-08-2011, 12:42 PM   #7 (permalink)
Most wanted
rohan_mhtr's Avatar
hey i too was intereted in buying the nexus s for my younger brother but i have some doubts
the indian version of nexus s has super lcd screen and not the amoled , whats the difference
also i have heard a lot of rumors that the lcd version i9023 has 256 mb ram as opposed to 512mb
all these things along with lack of card slot and fm has turned me in favour of lg optimus black , my brother wants a good looking phone with a descent sound quality . my budget is 19k .
Intel C2D E7500@3.5ghz 1TB*4 = 4TB HDD,4gb 800 mhz ram , XONAR-DX , Logitech Z 5500 !! HD4770,CM 500W extreme power +, Ipod touch 2g 8gb, Wave 2 .
rohan_mhtr is offline   Reply With Quote
Old 09-08-2011, 12:49 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
still, I think N:S is better than O:B
1. S-LCD or AMOLED has happened on many threads. do search a bit and you can also get lot of info on google
2. don't think so. what I heard is that on N:S, more amount of memory is dedicated to GPU, thereby reducing the amount available for the CPU.
3. it comes with 16gig onboard, so not to worry much about card slot
4. FM radio can be activated by loading custom ROMs
5. N:S audio quality is definitely among the best.
desiibond is offline   Reply With Quote
Old 09-08-2011, 04:39 PM   #9 (permalink)
Which store in B'lore is offering Nexus S at the best price?
s_holmes is offline   Reply With Quote
Old 09-08-2011, 05:41 PM   #10 (permalink)
dharmil007's Avatar
in Local stores in Mumbai, u can get a S-AMOLED version of NexuS s
Old 09-08-2011, 10:36 PM   #11 (permalink)
The Amoled version was not officially released in India. Maybe you get the imported versions from some other country in the shops you enquired.
Old 10-08-2011, 09:22 AM   #12 (permalink)
ruturaj3's Avatar
For how much u purchased it and in mumbai from which shop. On mobile stores site they are quoting 25k.
SGS II
ruturaj3 is offline   Reply With Quote
Old 10-08-2011, 05:09 PM   #13 (permalink)
dharmil007's Avatar
i Havent purchased it yet.
But thee price they are quoting is 19k
Old 10-08-2011, 07:58 PM   #14 (permalink)
its now out of stock...cant get
Core-i5 2400 | Intel DH67BL | G.Skill 8GB DDR3 1333Mhz | 500GB Segate | CM 430 | Corsair VX550 PSU| BENQ V2410 eco LED Monitor | Genuine windows 7 64-bit Ultimate | Samsung Galaxy S & boring Nokia Lumia 800 :(
noob is online now   Reply With Quote
Old 10-08-2011, 08:39 PM   #15 (permalink)
Sin
^ Ya..
same here..
been waiting for more than a week...
»~$in~«
sinoop_joy is offline   Reply With Quote
Old 10-08-2011, 08:59 PM   #16 (permalink)
Bond, Desi Bond!
desiibond's Avatar
you better get it asap if you want it else wait for SGS:R. Soon, the N:S will be out of stock. looks like bloody samsung is pulling it off the market as it is hurting the sales of SGS and SGS:L
Old 10-08-2011, 09:22 PM   #17 (permalink)
Sin
Ya..
Whenever i called the store, the salesman was forcing me to buy Galaxy S.
»~$in~«
Old 11-08-2011, 09:37 AM   #18 (permalink)
Originally Posted by sinoop_joy View Post
Ya..
Nexus S is out of stock in both Letsbuy and Flipkart. Also I enquired in a couple of stores here in B'lore and they said they are not able to get the stock for this. So if you really want this phone then get it ASAP.
I myself am waiting for the release of Galaxy R. Hoping it is priced similar to LG Optimus 2X as both have similar specs..
Old 11-08-2011, 10:48 AM   #19 (permalink)
dharmil007's Avatar
is Galaxy R better then Nexus S ??
will it get faster updates &
a good support of the dev community like custom roms ???
Old 11-08-2011, 10:50 AM   #20 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. G:R is better than N:S
no it won't get the updates faster
yes, it may get better dev support but this one, we will get to know only after the phone is out across the globe
Old 11-08-2011, 11:35 AM   #21 (permalink)
dharmil007's Avatar
what would be the price ..... do u have any idea of it {any guess}
greater then 20k or less then 20k
Old 11-08-2011, 11:40 AM   #22 (permalink)
It will definitely be priced above 20k. My guess would be somewhere in the range of 25 - 26K, to compete with LG Optimus 2X.
Old 11-08-2011, 05:39 PM   #23 (permalink)
dharmil007's Avatar
my budget is less then 20k
so i better of with NexuS s ..... if i Can get iT
Old 11-08-2011, 06:14 PM   #24 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
Default Re: Bought Nexus S..... Queries
You will not find Nexus S with SAMOLED in India
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 11-08-2011, 06:49 PM   #25 (permalink)
dharmil007's Avatar
HeY i Have jus checked the store near my place, NexuS s is available there & is in Stock.
thE price he is quoting is 18.8k.
But the problem is that the fone is having an SC-lCd panel not AMOLED.
i was wanting an AMOLED panel.
Waht do u ppl. Think taht should i Buy this ????
& one more Thing, i Have jus read news Ice Cream SandWich is releasing in October.
ANDOIRD - iCE CREAM
So would NexuS s will be getting this update ??? {i Know that its a GooGlE fone & will be first to get the updates, but as its a Whole new OS, rather then just a minor change, so will it be getting update ?}
iS teh hardware compatible ??
There is a shop where they are tellin that they have S-AMOLED panel NexuS s, but it is outa stock, they are tellin me like this from past 10 dayz.
Old 11-08-2011, 10:32 PM   #26 (permalink)
Peak Oil is real!
AndroidFan's Avatar
1. Nexus S will definitely get Ice Cream Sandwich (ICS) update.
2. Super-Amoled Nexus S phones were not launched in India. They are available in the grey market, but warranty can be a problem.
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 11-08-2011, 10:42 PM   #27 (permalink)
Mozilla Rep
sygeek's Avatar
ANDOIRD - iCE CREAM
From your previous posts, you sound like a fan of Nexus S. I say, just go for it. And regarding the updates, yes, it will get the Ice cream update sooner than other phones, but a little after Android 2.4 ready smartphones (like Incredible S).
Stop thinking, just go for this phone now.
Old 11-08-2011, 10:57 PM   #28 (permalink)
dharmil007's Avatar
Nopes i m not a fan of NexuS s ...... But i cant find any good fone in my budget i.e. less then 20k
So isnt NexuS s better then anyOther fone in 20k price Range ??
what do u Think ?? What is ur opinion ??? Waht would u suggest ??
Old 11-08-2011, 11:27 PM   #29 (permalink)
Mozilla Rep
sygeek's Avatar
For now, Nexus S seems to be the best buy under this budget. Buy this phone, period.
