29-07-2011, 01:52 PM
The Master Chief
Do Nokia priority Dealers fix Nokia Mobile phones??
Hey guys,i need to fix my nokia n82...its more software than hardware prob..where my battery from full goes to nil & switches off my cell phone.Also my music player is not able to add new songs in its playlist while refreshing...& i also need to update my firmware...So who will do this in mumbai???Any idea who fixes these problems??
Pls help
Intel Core I5 2500K,Gigabyte GA P67A UD3 B3,Corsair Vengeance 4gb DDR3,CM430 Cabinet,Corsair VX550W,Razer Cyclosa Bundle,Seagate 250GB,500GB,1TB,MSI 5770 hawk
29-07-2011, 02:12 PM
New Gen Guru
Re: Do Nokia priority Dealers fix Nokia Mobile phones??
I dont think Nikia priority dealer can fix anything...u have to go to nokia service center for that...or if u want to get hassel free service go to a local service center and check it.
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
29-07-2011, 02:42 PM
The Master Chief
local service centre???As in??Local guys on the street??But will they update the firmware??
29-07-2011, 03:07 PM
New Gen Guru
Actually yes..most of the time they solve the software issue by hard resetting or firmware updating....
Photography Gears -
29-07-2011, 03:11 PM
IF you take it to any local guy it will VOID WARRANTY
Go to any NOKIA CARE SHOP
29-07-2011, 03:30 PM
Fullbring
Warranty is already over...
@Ronnie11: take it to Nokia Care Centers & there they will update the firmware & take the required amount for that.
u can also update the firmware @ home if u know how to
29-07-2011, 05:10 PM
New Gen Guru
yaah N82 warranty must be over long back...
I hate nokia service center coz I have a bad exp with them...they kept my mobile for 3 weeks and then suggested me to go to a local shop coz they were too busy repairing under warrenty mobiles..
Photography Gears -
29-07-2011, 05:44 PM
Fullbring
for some its good but for some its bad...
29-07-2011, 05:55 PM
The Master Chief
yeah the warranty is over..ok cool...so nokia care centres then...will search & find out..how are they??do they do the job well??
i know i can update the firmware but my battery is erratic..the battery bar falls from full to nil all of a sudden..don't know what the prob is..so didn't want to risk in messing up the updates...
ahh damn..technically good but bad for me...so is it worthwhile trusting local shops??
29-07-2011, 05:56 PM
Fullbring
Change the battery to a new one...
afterall when u go to Nokia Care they takeout the battery,sim & give it to u.
they just take the body
N82 was my first fone & I still remember it..RIP
30-07-2011, 10:50 AM
The Master Chief
I am not sure if battery is bad or if firmware is causing this...but it does seem like a battery prob..oh i c...so battery is given back,didn't know that....N82 still works great for me...this is the first prob i faced in 3 years of its life...
30-07-2011, 11:23 AM
New Gen Guru
I have started trusting 1-2 local mobile repair shops...Nokia service centers r soo busy...and I cant leave my mobile for a weeks period in case any problem occurs..
Local mobile repair center will do everything before your eyes
Photography Gears -
