Old 26-07-2011, 11:07 PM   #1 (permalink)
Default Samsung Galaxy
Hi,
My cell phones speaker is not working (ring tone/songs not audible, but can listen when someone calls). Samsung service person says ringer to be changed. But this will lead to DATA LOSS---IS it so? This seems to be hardware problem, then why data loss?
Whats the simplest method to back up my CONTACTS of android (to restore in c/o loss)?
How to back up APPS?
joshiks7 is offline   Reply With Quote
Old 27-07-2011, 12:28 AM   #2 (permalink)
Default Re: Samsung Galaxy
first of all, changing H/W shouldn't lead to any data loss in any mobile till they change the entire PCB. still you should backup/sync your contacts to google servers. just enable GPRS/WiFi & in the account option select to sync whatever you want to backup but it is limited to only pictures, contacts & calendar i suppose.
for apps, if you are rooted, titanium backup is easy as well as efficient.
Old 27-07-2011, 08:30 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Originally Posted by joshiks7 View Post
Hi,
titanium backup is a great tool to backup everything. btw, did you check Kies? it should have backup/restore functionality.
desiibond is offline   Reply With Quote
Old 27-07-2011, 10:45 AM   #4 (permalink)
aniket.cain's Avatar
Kies does have an option to backup and restore the contacts. Just select all the contacts in Kies and export to pc as a .spb file. Later you can import them when you get back your phone. Or you can just sync your contacts with your google account and later sync back with your phone. Or you can use the option to Import/Export in Contacts menu on your phone to export the contacts to your micro sd card and then copy it to you pc to later Import it back to your device.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 27-07-2011, 01:25 PM   #5 (permalink)
why do u need backup via KIES ?
Sync contacts and SMS to Gmail.
Use SMS Backup+ for SMS,.
Speaking about apps, you can install it again..no big deal. or use titanium backup
Core-i5 2400 | Intel DH67BL | G.Skill 8GB DDR3 1333Mhz | 500GB Segate | CM 430 | Corsair VX550 PSU| BENQ V2410 eco LED Monitor | Genuine windows 7 64-bit Ultimate | Samsung Galaxy S & boring Nokia Lumia 800 :(
noob is online now   Reply With Quote
Old 27-07-2011, 03:09 PM   #6 (permalink)
Hi,
Thanks.
What is meant by "rooted"?
Old 27-07-2011, 06:57 PM   #7 (permalink)
giving administrator right to any app. once you are rooted & you try to use app that needs root access, it'll ask permission for root access.
Old 28-07-2011, 12:27 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
gaining inside access to a phone roots directory so that one can install 3rd party cracked apps/games...& customizing the phone according to user
