Old 24-07-2011, 08:40 PM   #1 (permalink)
Rohan_B's Avatar
Default LG Optimus One, Galaxy SL or Nexus S?
Hi I am looking to buy a phone strictly under 20K. I considered LG Optimus Black, Nexus S and Galaxy SL. Also the iPhone 3gs but its way too old now!! So please tell me which one should i get??
According to what I have read the Optimus Black is the best looking and most powerful!! So please suggest me which to get!!
Also which one has most support for ROMs and other mods?? Thanks!!
Where There Is Light, There Is Shadow..........
Peace Out
Rohan_B is online now   Reply With Quote
Old 25-07-2011, 12:42 AM   #2 (permalink)
Dev
dreatica's Avatar
Default Re: LG Optimus One, Galaxy SL or Nexus S?
Optimus black has battery issues and hardware issues just like Optimus 2x..google it. Galaxy SL is ok, but be ready to wait for the updates.
Nexus S will be the first to get the updates plus it supports tons of custom roms which will satisfy your needs. Just dont buy optimus black until the gingerbread update it out, it might solve the battery issues..but wont recommend to purchase it as of now.
dreatica is offline   Reply With Quote
Old 25-07-2011, 10:06 AM   #3 (permalink)
Bad to the bone
amitabhishek's Avatar
Without doubt, Nexus S.
Twitter: @amitabhishek
amitabhishek is offline   Reply With Quote
Old 25-07-2011, 10:09 AM   #4 (permalink)
Manc
xtremevicky's Avatar
Get Nexus S . Or If you can add to your budget there is a certain smartphone that you might interest you
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
xtremevicky is offline   Reply With Quote
Old 25-07-2011, 12:03 PM   #5 (permalink)
Explorer
aroraanant's Avatar
extend ur budget a lil bit n get Desire S...
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
Old 25-07-2011, 12:04 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
Nexus S
Old 25-07-2011, 01:52 PM   #7 (permalink)
dharmil007's Avatar
Dont buy Desire S, it has loads of battery issues.
Dont buy it.
instead Nexus S & Galaxy SL are good & it depends on what priorities u have.
Comparision btwn Nexus S & Galaxy SL
Nexus S
-ve points
-NO 720P recording
- NO microsd support
- No FM radio
- No smart dialing
+ve points
-Better Graphics Processor
-Super AMOLED Screen
-Faster Updates & lots of Custom ROMS
-LED Flash
Galaxy Sl
-ve points
- no Flash
-Slower Graphics Processor
-SC-LCD Screen {but both are almost same}
+ve points
-MicroSD Support
-Custom ROMS are gradually increasing & becoming available
-FM Radio
-720P Recording
-Gingerbread Update will be available s00n
dharmil007 is offline   Reply With Quote
Old 25-07-2011, 02:04 PM   #8 (permalink)
Dev
dreatica's Avatar
You should remove these two :
-ve points
-NO 720P recording
- No smart dialing
Both can be enabled if you flash custom rom.
Old 25-07-2011, 03:12 PM   #9 (permalink)
Terabyte's Avatar
@dharmil : First of all do you reckon you will be using more than 16GB?
AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Corsair 2x2GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
Terabyte is offline   Reply With Quote
Old 25-07-2011, 04:35 PM   #10 (permalink)
dharmil007's Avatar
iTs not like that he will be using 16GB or not.
iT is like if i have a MicroSD card support, then i can transfer many Things at fast speed, just by hot-Swapping memory card of my friends fone.
& secondly
YES.
iF i were to carry loads of music & hD Video clips, then 16GB would be very Much less
Old 25-07-2011, 04:44 PM   #11 (permalink)
Rohan_B's Avatar
Nexus S
-ve points
-NO 720P recording
- No FM radio
- No smart dialing
+ve points
-LED Flash
[/B]
Flipkart.com: Samsung Google Nexus S: Mobile
Nexus S availabe through Flipkart is having an S LCD Display.
Peace Out
Old 25-07-2011, 05:18 PM   #12 (permalink)
Terabyte's Avatar
AFAIK most of the Android phones don't have hot-swap.
Old 25-07-2011, 06:07 PM   #13 (permalink)
Rohan_B's Avatar
What hardware issues is the Optimus Black having?
Peace Out
Old 25-07-2011, 06:27 PM   #14 (permalink)
SeenuGuddu's Avatar
-ve points
-NO 720P recording
- No smart dialing
Can u enlight the statement in brief..
SeenuGuddu is offline   Reply With Quote
Old 25-07-2011, 08:45 PM   #15 (permalink)
this with eyes closed.
Core-i5 2400 | Intel DH67BL | G.Skill 8GB DDR3 1333Mhz | 500GB Segate | CM 430 | Corsair VX550 PSU| BENQ V2410 eco LED Monitor | Genuine windows 7 64-bit Ultimate | Samsung Galaxy S & boring Nokia Lumia 800 :(
noob is online now   Reply With Quote
Old 26-07-2011, 08:17 PM   #16 (permalink)
dharmil007's Avatar
in Nexus S can we play all videos ??
all formats {mkv, avi, mp4, wmv, etc} & at all resolutions ?? {atleast till 720p} ??
does it support subtitles ??
& lyrics in the music player ???
PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 2x2GB Dual-Channel DDR3 || 500GB WDC || Logitech MX518 || Samsung 20" LED SA20A300N
Old 26-07-2011, 10:11 PM   #17 (permalink)
Rohan_B's Avatar
Well I would've really liked 720p recording!! what if I extend my budget slightly and get the samsung galaxy s instead?
Also please tell me the difference between LG Optimus Black and Nexus S coz if there is not much difference then i would really love to get the Optimus Black!
Peace Out
Old 26-07-2011, 10:27 PM   #18 (permalink)
Terabyte's Avatar
^Nexus S has much better Processor and GPU, not to forget that Nexus S will get Ice Cream(next version of Android) first and Black is still on FroYo.
Old 27-07-2011, 11:01 AM   #19 (permalink)
Dev
dreatica's Avatar
If you flash custom roms, these features can be enabled.
Its still on froyo, and people are complaining about battery issues etc. You can visit xda for the optimus black and check out how many issues users are complaining about black. Until LG release an update for black, I wouldn't recommend it. If you seriously want to buy it, wait till an update comes out and resolves the issues like battery drainage etc.
you can enable the 720p recording in Nexus S by flashing custom roms. Also, there are tons of beautiful roms like MIUI, AOSP, Google MIUI rom and check out the videos about this rom. The best rom I feel for theme lovers and AOSP rom for performance.
For Optimus black, there are few unofficial roms (with bugs) as LG hasn't released an update of Gingerbread.
