Old 22-07-2011, 10:30 PM   #1 (permalink)
Question nokia c2-01
Flipkart.com: Nokia C2-01: Mobile
i ve seen this phone very economical @rs.3900 which comes with 3g.
i just wanted to know one thing..if i connect the phone to internet using 3g, and then can i connect this phone to my laptop using a datacable (phone acting as modem) so tat i can use this internet in my laptop ?
rajiv.ganti is offline   Reply With Quote
Old 22-07-2011, 11:50 PM   #2 (permalink)
the m0nk who sold his PC!
MatchBoxx's Avatar
Default Re: nokia c2-01
Ofcourse you can, but you need to install Nokia PC Suite in your laptop to set up the connection on your lappy
Intel i5-2400 || ASUS P8H77-M || G.Skill RipjawsX 8GB (4GBx2) || MSI HD6850 Cyclone PE || Corsair GS600 || Cooler Master Elite 431(Side Panel) || Dell ST2220L || Edifier C2 || APC 1.1 kVA || Seagate GoFlex 1TB
(WBUT semester routine announced. I'm OFF for the time being.)
MatchBoxx is offline   Reply With Quote
Old 23-07-2011, 01:46 PM   #3 (permalink)
does the nokia pc suite support this mobile?
Old 23-07-2011, 02:04 PM   #4 (permalink)
New Gen Guru
sujoyp's Avatar
Either it will be the old PC suit or the new OVI suite...
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline   Reply With Quote
Old 23-07-2011, 02:18 PM   #5 (permalink)
MatchBoxx's Avatar
PC Suite and Ovi Suite has different functions.
Old 23-07-2011, 02:32 PM   #6 (permalink)
In the phone confguration, they mentioned that it has OVI store installed..
so i think it supports OVI suit??
by the way, what is the difference between the functioning of pc suit and ovi suit?
Old 23-07-2011, 03:00 PM   #7 (permalink)
Nokia Ovi Suite
check the list. Nokia C2-01 is mentioned. so it is supported.
Nokia Ovi Suite have better design & functionally. & Wikipedia says this:
Nokia Ovi Suite is replacement for Nokia PC Suite and is integrated with the Ovi brand of services.
tested Nokia 2700C with both PC as well as Ovi suite & Ovi suite gives access to Ovi services straight from the software.
Old 23-07-2011, 03:13 PM   #8 (permalink)
New Gen Guru
sujoyp's Avatar
ovi suit is the latest one..Its a good software with simple UI
worst thing is that they update every 2 months..and tell us to update 30-40 mb..
Photography Gears -
Old 23-07-2011, 03:29 PM   #9 (permalink)
i like the internet setting. either select country & service provider (if it is listed) or enter apn.
i really wish the other phone manufacturers spend just 5min & look at PC/Ovi Suite.
Old 25-07-2011, 12:46 AM   #10 (permalink)
Dev
dreatica's Avatar
/offtopic/
You don't even need to enter such details when u tether Android device with usb..just cable drivers and you are good to go. @Sam If I am correct, you are using Optimus one? I never thought u would be saying this.
dreatica is offline   Reply With Quote
Old 25-07-2011, 01:05 AM   #11 (permalink)
Originally Posted by dreatica View Post
/offtopic/
i have done only WiFi tethering, not usb tethering. so not much idea about it
Old 25-07-2011, 02:09 AM   #12 (permalink)
MatchBoxx's Avatar
/offtopic/
Sam has mentioned the Manual Configuration option...if the network settings are already configured on the phone, then no need to select any option from the Suite, just click on "Connect" and u r online!
