Old 22-08-2005, 05:07 PM   #1 (permalink)
expertno.1's Avatar
Default Mobile Charging through data cable help !!!!!
i bought the mobile LG G3100 beco of the boring bsnls dialup and now i am a gprs user
but i also bought the data cable for it which has a hologram of lg on it
but mobile connected with computer using data cable do not get charged
why is this so ?
any way to charge ?
also
i have also a Samsung SGH-N620 mobile phone which is 2.5 years old
suddenly i plugged it into the lg's data cable and hrray it was being charged
now the conclusion
the lg data cable is not charging its own company mobile (Lg G3100) but charging samsungs mobile
now what the hell is this ?
expertno.1 is offline
Old 23-08-2005, 11:49 AM   #2 (permalink)
are you sure you are using datacable for charging mobile??
datacable connects the fone to computer to transfer files. and you will have a seperate charger for charging the fone
kaysquare is offline
Old 23-08-2005, 11:53 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
It depends upon the PIN Outs buddy!
May be the PIN for charging the LG mobile is different from the Samsung.
And its a coincident that the cable's PIN matches ur Samsung's PIN?
Thats why the cable is charging the Samsung but not LG...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 23-08-2005, 01:47 PM   #4 (permalink)
MVP in VC++
Default Re: Mobile Charging through data cable help !!!!!
u r using the Data cable to charge the mobile...can it be done????
cvvikram is offline
Old 23-08-2005, 04:51 PM   #5 (permalink)
yes, even the k750i charges automatically when connected to the USB port
Maaxxx, dearest of all my friends!
Abhijit_T is offline
Old 23-08-2005, 04:53 PM   #6 (permalink)
Hells_Fury's Avatar
I dont know about LG phones, but i have a Nokia 6230 and the phone does not get charged when the data cable is attached. I have to charge it using the charger.
Check your phone user manual to see if this feature is supported.
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 23-08-2005, 09:03 PM   #7 (permalink)
expertno.1's Avatar
yes i charge my samsung mobile using DATA CABLE
Old 23-08-2005, 09:23 PM   #8 (permalink)
expertno.1's Avatar
but what about LG ?
