Old 18-07-2011, 06:22 PM   #1 (permalink)
pmkarun's Avatar
Question Need Qwerty Mobile around 5K
Hi All,
I am planning to buy a new mobile within August First week..
My requirements are as follows:-
1. Budget?
5K(Plus or Minus 0.5K)
2. Display type and size?
No Preference
3. Form Factor?
No Preference
4. Preferred choice of brand?
Except Micromax & Karbon
5. Preferred input method (QWERTY, touchscreen, numpad, touch-n-type).
Qwerty Preferred
6. What camera option you want? Please specify need for flash, autofocus, front facing camera.
Should be at-least 2.0MP
7. Preferred operating system?
No Preference
8. Preferred connectivity options (3G, Wifi etc)Please specify clearly.
3G/WiFi Preferred
9. Preferred applications (Flash, Swype, GPS, etc)?
No Preference
10. Primary use of handset (multimedia, camera, mails, internet, gaming etc)?
Mostly making calls, heavy texting, Browsing, Music sometimes
11. Any specific mobile phones in consideration?
Nokia C3(Even it is higher than my budget one eye is on it)
Samsung Corby Plus
Kindly suggest me some other mobiles also....
pmkarun is offline   Reply With Quote
Old 18-07-2011, 08:43 PM   #2 (permalink)
Terabyte's Avatar
Default Re: Need Qwerty Mobile around 5K
^Go for Nokia C3 although it doesn't have 3G it does have WiFi.
It is difficult to have both WiFi, 3G and QWERTY under 5k
AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Corsair 2x2GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
Terabyte is offline   Reply With Quote
Old 18-07-2011, 09:29 PM   #3 (permalink)
BIOS Terminator
nims11's Avatar
its difficult to get the ur desired features under 5K.
you can get X2-01 for 3.8K.
or you can increase your budget to 7.7K and get E63. it has all features you want and it is a good phone.
i own both X2-01 and E63.
nims11 is online now   Reply With Quote
Old 19-07-2011, 12:04 AM   #4 (permalink)
Believe Me or Not!!!
Samsung Ch@t 335 - qwerty phone with WiFi (no 3G)
NainO is offline   Reply With Quote
Old 19-07-2011, 08:53 AM   #5 (permalink)
pmkarun's Avatar
I don't want 3G and Wifi in the same mobile.
Either one of them will do
And When I checked for Samsung Chat 335 flipkart says that "Permenantly Discontinued"
Is there any other mobile having these features????
Old 19-07-2011, 11:39 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
you may need to go Micromax way for those features. at 2k+, you can get Galaxy Pro and E63, which are pretty good devices.
desiibond is offline   Reply With Quote
Old 19-07-2011, 12:04 PM   #7 (permalink)
pmkarun's Avatar
How is Lava B8???? Look good on Paper..
Is lava a trustable brand???? or same way like Micromax& Karbon??????
Old 19-07-2011, 12:18 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I think it's worse than MM but honestly, all of these are of same kind. YOu need to have lot of luck.
Old 19-07-2011, 08:45 PM   #9 (permalink)
Dude are you kidding me??..how can you even think that Lava is a trustworthy brand??Of all these cheap-a$$ companies only Micromax seems to be relatively(being the operative word) better than others!!n when I say "others" it includes all those cheap-a$$ companies you can think of(Karbon,Maxx,Olive,Lemon, Zen & God knows what)...
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
ssb1551 is offline   Reply With Quote
Old 19-07-2011, 10:03 PM   #10 (permalink)
aniket.cain's Avatar
I'd say increase the budget to 7.5k and get Galaxy Pro from letsbuy. Nothing matches it at this price point. Otherwise you could go for Nokia X2-01 for around 3k. It hasn't got any of those features, but it has very nice keypad and solid build quality. Trust Nokia on making good quality cheap phones.
Gsmarena has given a good review to this one.
HP DV6-6121TX | XBOX 360 | Omnia W | Cowon J3 | Sennheiser HD 598 | Klipsch Image X10i
aniket.cain is offline   Reply With Quote
Old 19-07-2011, 10:22 PM   #11 (permalink)
pmkarun's Avatar
Smile Re: Need Qwerty Mobile around 5K
Just asked about it as One of my friend told that its good
Thats all
How about going for Low price android Mobiles like Spice MI-270????
Is it good???? after applying icicilb code I m getting the mobile for 5.1...
Is it worth????
Confused with Nokia C3 or Spice-MI-270
Which one to buy????
Old 19-07-2011, 11:35 PM   #12 (permalink)
I think lower priced android phones from Micromax etc dont have enough powerful hardware to handle Android properly. Even the HTC Wildfire doesn't seem that fluid. These cheaper Spice phones will become more of a headache soon as you install apps and stuff. C3 might be a better option imho.
Old 20-07-2011, 12:29 AM   #13 (permalink)
@pmkarun, if you are ready to go for local brands but want Android, minimum you should get is Micromax A70. specs are descent & at least spec wise it should be usable. but with the el-cheapo mobiles like Spice M-270/Andro, the screen is small & resisitve, processor is either slow & also ram is too low to make it any usable.
if you can't increase your budget, stick to your QWERTY phone plan & get C3.
Old 20-07-2011, 09:22 AM   #14 (permalink)
Terabyte's Avatar
@karun: Go with C3 and forget budget-Androids!
Old 20-07-2011, 07:25 PM   #15 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
C3, just go for it
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline   Reply With Quote
