10-07-2011, 04:07 PM
Phone in less than 5-6k, with capacitive touch if possible.
1. Budget?
5000 (MAX:6000)
2. Display type and size?
what is this??
3. Form Factor? bar, slider, flip?
Touch(bar?)
4. Preferred choice of brand?
None...
5. Preferred input method (QWERTY, touchscreen, numpad, touch-n-type).
Touchscreen/touch n type
6. What camera option you want? Please specify need for flash, autofocus, front facing camera.
No choice...
7. Preferred operating system? (Android, Symbian, iOS, Windows Phone etc).
Android
8. Preferred connectivity options (3G, Wifi etc)Please specify clearly.
Nothing, but I would like WiFi.
9. Preferred applications (Flash, Swype, GPS, etc)?
N/A, as long as I could install more apps!
10. Primary use of handset (multimedia, camera, mails, internet, gaming etc)?
Texting + Calling + Internet
11. Any specific mobile phones in consideration?
N/A
12. Any other info that you want to share
I know that in my budget, not all the things I want will be present, but I want a phone with the nearest possible requirements. I don't want to extend my budget by even a rupee. I would like a CAPACITIVE touchscreen, and this is my most important need. The next to this is Android's need.
I wont be using the phone for more than a year, if that info is also needed!
10-07-2011, 05:10 PM
Re: Phone in less than 5-6k, with capacitive touch if possible.
You can get a Samsung Galaxy 3 @Rs.7,500
Good Android phone
10-07-2011, 05:13 PM
Whompy Whomperson
Good Android phone
but its out of OP's budget... :O
10-07-2011, 05:17 PM
Good Android phone
please suggest something under 6000
10-07-2011, 05:54 PM
Peak Oil is real!
I have heard Monte had a capacitive screen... should be available for around 6k now that it is outdated...
Also, Wave 525 has a capacitive screen as far as I know... and it costs around 6.5k... but recently it was on some website for as low as 5.5k after coupon code...
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
10-07-2011, 06:37 PM
EXIT: DATA Junkyard
6k? I strongly recommend extend your budget to 6.9k, it would be well truly worth it.
http://www.letsbuy.com/samsung-galaxy-3-i5801-p-10739
Use this coupon: RCOMLB1
10-07-2011, 07:02 PM
i understand OP's needs but for 6k you'll find Android mobile but with cheap interiors that will make using it highly unpleasant. you may feel really excited at using it for the first few days but as soon as you use one of the 8-12k Android you'll feel why we always advice again using the cheap Androids.
so i'll suggest you this: Samsung Wave 2. though it comes with BADA, it is at least usable than those 2.8" resistive screen packed rebranded-Chinese Androids flooding the indian market.
only Android mobile within your budget is Spice Mi-270. & its only +ve point is it comes with Android 2.2 & hence will be more smooth as well as allow apps/games to be installed in memory card.
PS: Andro is flop.
Originally Posted by comp@ddict
6.9k for a G3 is a steal. it packs H/W that matches 9-10k costing LG Optimus One.
now only if OP is willing to spend that extra 900 bucks.
10-07-2011, 10:14 PM
I cant extend my budget... but I can wait for about 6-7 months, and ask my mother on passing 10th to get an expensive phone...
But I guess I can have Optimus One or Spice Mi-310 then, so which is better(I know O1 is, but how is it better when features are almost same?)
Until that time, if I can have a phone for about 4-5k, I guess cookie fresh is nice, what do you think?
11-07-2011, 12:12 AM
6-7 month? i guess then we'll have a whole lot of different budget smartphone with specs found in 18-20k mobile now.
for 5k, if you want touchscreen, get Nokia 5230/5233. old but still more usable than the cookies & corbies.
11-07-2011, 12:47 AM
iGoogle
Ya infact right now dont waste your cash. Complete your 10th,concentrate on it. You dont need a high end phone anyway right now. Get a basic phone within 5k like Sam suggested. Do well in your 10th, impress you parents and then rightfully ask for a full featured phone with your report card in hand  I doubt they will deny you. Then 2 yrs in junior college you can enjoy ur cool phone
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 :2subs: | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | LG optimus one
11-07-2011, 09:20 AM
EXIT: DATA Junkyard
Bro, study for 10th, then get new phone and enjoy 11th (and again study in 12th okay!!)
