Old 21-08-2005, 01:52 PM   #1 (permalink)
tweety_bird_bunny's Avatar
Default mp3 nokia 6600 quality
i'm gonna buy nok6600 as it offers decent features at reasonable price....
if i download any mp3 player software on it ..n listen to my music files thru the nokia headset,, will the quality be good ???i mean it will play as a clean file or with hicups n noises of all sorts?????
plz tell me about it.... n also where can i download softwares for nok6600.....plz keep the topic around 6600 n not about other phones...
tweety_bird_bunny is offline
Old 21-08-2005, 02:03 PM   #2 (permalink)
macaddict
gauravsuneja's Avatar
<snipped>
Edited by drgrudge Illegal site!
gauravsuneja is offline
Old 21-08-2005, 02:07 PM   #3 (permalink)
well i will sugest u 2 not to go with 6600. u can use ultra mp3 for ur purpose but quality may not be satisfactory
if u can forget camera then go for german-engage easily available in grey mart..
problems with 6600
1. bad realy very bad quality of vga camera. try to look tose pics on pc.
2.bad software /OS.
3.low audio quality.
4.low quality loud speaker( is it realy loud then take a look at E398)
5.slow gprs transfer speed.
6.moat important ETC.
problems with german engage
1.no camera.
2.only available in gray mart i.e without bill.
rest it rock.
all u got is either 0 or 1 there is no place for 1/2 same is also true for life.
vegeta_killer is offline
Old 21-08-2005, 02:12 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Nope there wont be ny problem, but the audio quality is bad...
I mean no breaks but bad music and bass...
@vegeta_killer - U mean that u r air (refferin ur location...) no offence but is ur face stuck to the screen and seat ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-08-2005, 02:51 PM   #5 (permalink)
Just Do It
Charley's Avatar
problems with 6600
2.bad software /OS.
1.no camera.
rest it rock.
This is what he wrote.
Charley is offline
Old 21-08-2005, 03:25 PM   #6 (permalink)
Commander in Chief
How cud u be such staunch ?
He's jus tellin indiretly that tis not good....
p.s.>Y hasnt ur warnin gone off, it has been a month now...
Harsh J
www.harshj.com
Old 21-08-2005, 05:35 PM   #7 (permalink)
hack expert's Avatar
well if ur buying a cell n if u like music then 6600 is not a bit worth it sound quality suck`s bad
if music then ngage is the best i myself have one (no cam)
if u need cam there are many other phone`s motorola etc etc with good sound quality
i kno u have asked to keep upto 6600 but this are just suggestions final decession is upto u
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 21-08-2005, 06:10 PM   #8 (permalink)
its just 6600 bcoz i came to know that it has symbian OS....n the ngage doesnt have good keys......thats y i'm inclined towards 6600....
Old 21-08-2005, 06:20 PM   #9 (permalink)
Another Brick in the Wall
drgrudge's Avatar
{Sound in 6600}
http://www.thinkdigit.com/forum/view...highlight=6600
{How to play mp3 in 6600}
Thats none for your business and you are warned.
Moved here
drgrudge is offline
Old 22-08-2005, 11:56 AM   #10 (permalink)
mariner's Avatar
if music is the only criteria than go for engage. otherwise 6600 is a cool cell.
mariner is offline
Old 17-10-2005, 12:24 PM   #11 (permalink)
CCIE# 20863
Well,
I bought 6681 recently, and I dont think I have ever heard that much gr8 quality stereo MP3 on other handsets....
theKonqueror is online now
Old 21-10-2005, 08:44 PM   #12 (permalink)
thrash_metal's Avatar
Well the quality of music in 6600 / 6670 sucks big time but this is what you can do to get the best of what you have. Open the mp3 file in a eqalizer on ur Pc , look at the graph ( a graphic eqalizer is preferred to a parametric one ) . As the diameter of the cone in the speaker in ur Nokia is small its good for trebble than base and mids . Reduce all the frequencies below 500hz to - 6 or -7 or maybe even elliminate em . from 500Hz to say 3500Hz reduce the frequencies to -1 to -3 . And Boost the frequencies above 3500Hz by 3 to 4 !!
Rather if you have a better software you can boost the base frequencies to round 400Hz from 350Hz and you have a good track ! The quality you then get is way better then what you get if u just send a mp3 file to the phone ! Remember not to overboost the files to avoid jaaring !!
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
