Old 07-07-2011, 01:01 PM   #1 (permalink)
change is constant!!
khmadhu's Avatar
Unhappy help downloading files from wave s5253
Hi,
any samsung wave user, please share some tips and tricks how to download files from using a good browser.
tried downloading files with opera and UC browser, although i can browse the web but when it comes to downloading the browser does nothing.
in opera: it asks where to save the download and after that it shows downloading status but doesn't download anything, also shows no error.!
in UC browser: connection timed out.
please anyone help me in this.. i am really getting exhausted with this phone. .
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 11-07-2011, 05:37 PM   #2 (permalink)
Default Re: help downloading files from wave s5253
What carrier are you on? Vodafone? Airtel?
Vodafone Live! has all ports blocked except port 80.
ALso regarding the Opera download issue, wait a little while. Open a file manager and check if the downloaded file has actually increased in size. If it does then download is on normally
Old 11-07-2011, 07:54 PM   #3 (permalink)
6x6
half way there
6x6's Avatar
what are you trying to download?
I am having wave 525. I download files / mail attachments using opera mini and default dolphin browser. both works fine.
Intel C2D | G31 | 2GB | 320GB
6x6 is offline   Reply With Quote
Old 12-07-2011, 10:54 AM   #4 (permalink)
khmadhu's Avatar
@thetechfreak
I am connecting through my belkin wifi router which is connected to airtel broadband.
never checked the file size growth.. but will check that..
@6x6
how come u r able to download from dolphin. by default dolphin doesn't support exe and other file downloads
I am trying to download some big exe files like crysis2 updates and also some video files hosted in some file sharing sites..
Old 12-07-2011, 11:29 AM   #5 (permalink)
As you are connected via wi-fi there is NO REASON WHY FILES WONT DOWNLOAD.
Dont worry. File size will reveal it
Old 12-07-2011, 10:08 PM   #6 (permalink)
khmadhu's Avatar
@thetechfreak no luck the file size remains zero!. after few minutes the opera mini gives download failed error. also there is no activity in internet usage(modem lights remains constant).
I don't know whats the problem..
Old 13-07-2011, 10:15 AM   #7 (permalink)
Can you download via GPRS atleast? Does laptop work with Wi-Fi? The net is working right?
Old 13-07-2011, 11:04 AM   #8 (permalink)
khmadhu's Avatar
@thetechfreak
I dont have GPRS enabled in my mobile. all my Laptop and desktop wireless are working fine..
is opera mobile 11 compatible with wave 525..? if so i can use that instead of opera mini 6.1
Old 13-07-2011, 09:44 PM   #9 (permalink)
6x6
half way there
6x6's Avatar
^ why you want to download exe files in mobile, they dont work in bada.
i download normally word, excel, pdf, jpeg and jar files - they can be downloaded without any problem.
PS: i checked downloading one exe file (winamp lite -7MB) using wifi. dolphin browser shows "content not supported" error. opera mini was downloading file and it went upto 70-80% and then my internet got disconnected .
i think, in opera mini if we open some other application while downloading or mobile displays goes black due to power saver, downloading is paused - not sure as my internet was not consistant today due to raining in my area.
Old 13-07-2011, 10:37 PM   #10 (permalink)
khmadhu's Avatar
^ usually I download exe files which are less than 300MB from my PC.
if its more than a GB then i go for mobile.. that saves lot of power.. going green. .
yes sometimes I too experienced that opera mini gets paused while opening other apps.
