LinkBack (2) Thread Tools Display Modes
Old 02-07-2011, 12:30 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Imperial_Raj's Avatar
Default Need a MP3 player for my phone
Hello everyone! I'm currently using a Nokia 5233 and its music player was working fine till I shifted some songs from the 'Downloads' folder to the 'Sound Files' folder. Some songs are missing after that and my music library, which was earlier of nearly 12 hours, is now only of 8 hours.
So, what could be the cause of the problem. Has anyone of you had such a problem before?
Also, please suggest me a good mp3 player for this phone as I am not much satisfied with the Ovi Player built-into this phone.
Thanks in advance
Imperial_Raj is offline   Reply With Quote
Old 02-07-2011, 12:48 PM   #2 (permalink)
Default Re: Need a MP3 player for my phone
You need to refresh Music libary.
Open the music player then
options>select refresh music library and wait for some time
Old 02-07-2011, 09:38 PM   #3 (permalink)
@thetechfreak - I've done that thrice since shifting the songs but to no avail.
Any suggestions for a good player for all my songs, anyone?
Old 03-07-2011, 03:14 AM   #4 (permalink)
Dr.tweaker's Avatar
Tune Wiki ,find it in the OVI Store for free (free version), with lyrics support and lyrics search features integrated all the way, or TT Pod ( you can very well download it from various forums,a quick search across google will do (The latest version also provides a mini player on homescreen as you minimize it and the player itself has a plethora of skins to its disposal and ample options to pump up the sound quality)
Hail Metal \m/
Nokia X6
Nokia E5
Dell Inspiron 15"(Dun fu**in really care bout the suffix,does my geeky chores,that's it)
a 500 GB (priceless,every bits of it) music repo.
Gold Flake,OMR
Dr.tweaker is online now   Reply With Quote
Old 03-07-2011, 10:02 PM   #5 (permalink)
Hail Metal \m/
Thanks a lot Doc.
Tune Wiki is great yet it cannot edit my song details. And for TT Pod, I am usually finding the Chinese version on Google. But I found some links for the English version and would be trying it out soon.
Old 04-07-2011, 03:30 AM   #6 (permalink)
Dr.tweaker's Avatar
Originally Posted by Imperial_Raj View Post
Thanks a lot Doc.
There is a latest TT Pod English translated version(4.30) which has ID3 tag editing support as well which i came across across some forum
P.S : M not any doc,that's just a profile handle, I'm a techie (and a management ka baanda by destiny), but more of a musicoholic
Nokia X6
Nokia E5
Gold Flake,OMR
Old 05-07-2011, 06:29 PM   #7 (permalink)
I've downloaded TT Pod 4.3 En but after installation ot just refuses to start. I've reinstalled it but in vain. What could be the problem and its solution?
@ Dr. Tweaker - I did not actually intend to designate you as a usual Doctor but I meant Dr. Music since you helped me in my trouble with music.
Old 05-07-2011, 09:33 PM   #8 (permalink)
Project Halcyon V2.0
tkin's Avatar
Thanks in advance
I had, the music library corrupts itself from time to time(on my 5800).
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 06-07-2011, 04:38 PM   #9 (permalink)
@ tkin - So how did you solve the problem?
Old 06-07-2011, 06:47 PM   #10 (permalink)
tkin's Avatar
I take backup and format my phone once a month, that's the only way if memory card itself becomes corrupt(file system).
If the library gets corrupt you can do this:
1. Put phone in Mass Storage mode (its in the settings/connectivity/USB section)
2. Plug in the USB cable and go to Windows Explorer
3. Navigate to the private folder on your phone, search in windows explorer search bar for files starting with:
pcv
mpx
harvesterdb
and delete them all
4. Restart phone after disconnecting usb cable.
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/143250-need-mp3-player-my-phone.html
Need a MP3 player for my phone - Digit Technology Discussion Forum This thread Refback 16-07-2011 10:23 PM
Need a MP3 player for my phone - Digit Technology Discussion Forum This thread Refback 16-07-2011 10:22 PM
