30-06-2011, 01:38 PM
Best phone for 14000-15000
I m looking for a good camera phone within that price bracket ..should i wait for xperia mini pro to release?
30-06-2011, 02:43 PM
Re: Best phone for 14000-15000
Do you have any preference for OS??
Android - Moto DEFY
Non-Android - Nokia C6-01
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
30-06-2011, 03:11 PM
The High 5 Flyer
Samsung Galaxy ACE
30-06-2011, 03:20 PM
Reccomendation from my side- Motorola Defy
30-06-2011, 04:11 PM
Fluidic design!!!
My recommendation is Nokia C6-01. Iam also going to buy it after a few days.
ASUS P5K-VM|Intel C2D E7200 2.53 GHz|Kingston 3gb DDR2 800MHz|XFX GT240 1gb|WD 160gb, Seagate 500gb|CM 350W PSU|Zebronics Antibiotic|BenQ G2220HD|Moser Baer DVD-RW|Logitech MX518
30-06-2011, 04:38 PM
No offence but how on the earth can you recommend Defy when OP is looking for a camera phone
@OP : Check either Nokia C6-01 or Samsung Galaxy Ace.
AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Corsair 2x2GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
30-06-2011, 05:09 PM
EXIT: DATA Junkyard
For camera phone, I suggest Nokia C6-01.
30-06-2011, 05:11 PM
Both DEFY & Ace have 5MP with all the same features but ACE records at pathetic QVGA resolution whereas DEFY records at VGA.I don't see the logic of recommending ACE on the basis of camera let alone the fact that DEFY is better than ACE hands down!!
Nokia C6-01 on the other hand is a clear winner with 8MP & 720p recording but OP hasn't mentioned whether he likes Android or not.
01-07-2011, 01:04 PM
Explorer
Would suggest u wildfire s
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
01-07-2011, 01:47 PM
║ Green World ║
If cameraphone is the only preference thn NOkia C6-01
01-07-2011, 02:02 PM
Believe Me or Not!!!
Go for - Nokia C6-01 or Motorola Defy.
I dont think Xperia Mini Pro would be in your budget, being a snapdragon-equiped phone.
01-07-2011, 04:59 PM
Where is OP?? No response from him!!
01-07-2011, 05:04 PM
Guys, please wait. I think OP is gone. No more suggestion till he comes back
04-07-2011, 01:15 AM
I dont have any OS preference for i am concerned only with basic functions.
1.camera
2.GPS (i think google maps will perform equally on both platform - android and symbian anna).
3. Nominal ebook reading.As of now I use Mobi Pocket Reader for ebooks and it is good enough for me.
I wont be using mobile for surfing though.For OS i dont want to go beyond Android or Symbian.
I can extend my budget 16500.... not beyond that.
Any info what would be the price of new Xperia Mini models?
04-07-2011, 01:18 AM
Get Nokia C6-01 then. Though if you really care for camera so much, why not buy a standalone camera + a cheap cell phone? That would be better IMO.
04-07-2011, 01:25 AM
flipkart is selling C7 for 16,732 means street price should be ~16k. go for it.
18-19k (most likely)
04-07-2011, 08:16 AM
EXIT: DATA Junkyard
1.camera
Nokia's Ovi Maps is a far far greater service, works offline too, takes a few seconds for the GPS to lock, best in class.
Camera of C6-01 can't be beaten, maybe the auto-focus is missing, so no macro shots, but everything is far superior to the android counterparts near C6-01's price.
I say again, the C6-01.
04-07-2011, 08:22 AM
Bond, Desi Bond!
yes. If Camera and GPS are priority, Nokia devices are the best, given that you are okay with Symbian OS. Do wait a bit for the new Nokia X7. It might push N8 under 20k making it one heck of a deal.
04-07-2011, 11:22 AM
#19 (permalink)
If camera is top priority & you "don't give a damn"(not trying to sound like Clark Gabble  ) then go for C7...you'll love taking those impromptu snaps & vids which you can't with a dedicated handycam. If you can't squeeze in that much amount then go for C6-01.
04-07-2011, 03:24 PM
#20 (permalink)
EXIT: DATA Junkyard
Well, either C6-01 or straight N8, best deals IMO. If N8 reaches under 20k, nothing like it!
09-07-2011, 11:22 PM
#21 (permalink)
i had made up my mind for c6-01 ,but when i compared the photo quality of defy and c6-01 from the tool in gsmarena i think that defy has better image quality and i m confused again
10-07-2011, 12:21 AM
#22 (permalink)
EXIT: DATA Junkyard
I still vouch for C6-01, better video, 720p and all that.
13-11-2011, 12:33 PM
#23 (permalink)
hey guys, even i am confused between c6-01 and motorola defy.
while the c6-01 packs in an 8mp cam compared to defy's 5mp, c6-01 is a fixed focus camera while that of defy is an auto-focus one.
Nokia also has better battery life than that of most of the phones, would like to know about the battery life of Defy.
Nokia also has a brilliant after-sales-service, what about that of motorola ??
however motorola steals the show with the android os, compared to symbian. But c6-01 has got the Anna update so that might be exciting.
So, i'd lyk u people to come up with some suggestions as i am confused as hell
thnkx guys
