Old 26-06-2011, 08:22 PM   #1 (permalink)
Default Help needed!! A phone around 15000
hey,
i needed a phone below 15000 and am getting motodefy for abt 14500..
can anyone plz tell if i shoud go about it.. or is there a better option?????
dereek is offline   Reply With Quote
Old 26-06-2011, 08:45 PM   #2 (permalink)
Default Re: Help needed!! A phone around 15000
Get the Motorolla Defy.
Also, look at this thread: http://www.thinkdigit.com/forum/mobi...on-thread.html
Old 26-06-2011, 08:59 PM   #3 (permalink)
go for it.
Old 26-06-2011, 09:35 PM   #4 (permalink)
Fluidic design!!!
himangshu's Avatar
Hi, If if you can live with Symbian then you can get C6-01 for 13.3k or if you want Android phones then get either Samsung Galaxy Ace(14.5K) or Motorola Defy(15K)
ASUS P5K-VM|Intel C2D E7200 2.53 GHz|Kingston 3gb DDR2 800MHz|XFX GT240 1gb|WD 160gb, Seagate 500gb|CM 350W PSU|Zebronics Antibiotic|BenQ G2220HD|Moser Baer DVD-RW|Logitech MX518
himangshu is offline   Reply With Quote
Old 26-06-2011, 10:05 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
If you want camera, C6-01 will be best in price.
And the screen is the best too, CBD is awesome, AMOLED FTW!
comp@ddict is offline   Reply With Quote
Old 26-06-2011, 11:01 PM   #6 (permalink)
Explorer
aroraanant's Avatar
Wildfire S is also a very good option...
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
Old 27-06-2011, 09:52 AM   #7 (permalink)
k just outta curiousity whats "CBD"??
I think Wildfire S has got a crappy screen resolution of 320×480 in a 3.2" screen.
AMD Athlon II X4 635 || Biostar MCP6P3 || 2GB Zion & 2GB Corsair DDR3 1333MHz || Seagate 1TB + Seagate 500GB || XFX HD4650 || FSP Saga II 500W || Zebronics Fantasy || LG W2043T
ssb1551 is offline   Reply With Quote
Old 27-06-2011, 10:07 AM   #8 (permalink)
Terabyte's Avatar
CBD = Clear Black Display, the technology Nokia uses on its AMOLED displays
Are you serious?
By no means 320x480 is crappy resolution.
Heck even iPhone 3GS has the same resolution for 3.5"
AMD Phenom II X4 955BE (Cooler Master Hyper 212+) || Gigabyte 785GMT-USB3 || Corsair 2x2GB DDR3 RAM || Corsair VX450W || NZXT Gamma || Logitech MX518
Terabyte is offline   Reply With Quote
Old 27-06-2011, 10:10 AM   #9 (permalink)
CBD means Clear Black Display. The c6-01 has it.
GSM Arena's Screen Showndown: Nokia's CBD AMOLED – best contrast, best colours, better sunlight readability than Super AMOLED! : My Nokia Blog
Old 27-06-2011, 10:29 AM   #10 (permalink)
Well maybe I've become so used to 640×360 resolution on a 3.2" screen that 320×480 looks bad. Does Corby has that resolution?? 'cause it looks really bad...or is it 240×320 in Corby?? Anyways my point being when compared to C6-01 resolution Wildfire S aint that great!!
Old 27-06-2011, 11:30 AM   #11 (permalink)
thnx everyone..
Old 27-06-2011, 11:43 AM   #12 (permalink)
nope. corby have 240X320 or 240X400 resolution. also corby were feature phones packed with resistive screen.
current android phones of 3-3.5" size have 320X480 resolution.
