Old 22-06-2011, 02:02 PM   #1 (permalink)
New Gen Guru
sujoyp's Avatar
Default Any custom ROM for 5800
Friends anybody uses custom ROM for 5800. I am bored with its interface and will get a new handset in Diwali...but for now
all the features should work on that ROM.
Please Suggest??
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
sujoyp is offline   Reply With Quote
Old 22-06-2011, 02:45 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: Any custom ROM for 5800
^^ OMG, so you don't know about CFWs?? Amazing.. The wonders.
Go here, and amaze yourself..
v5 Custom Firmware / Cooking - Files and Releases
I personally prefer these two CFWs:
(for 5230)
Phantom^1
InFiniTy^01
comp@ddict is offline   Reply With Quote
Old 22-06-2011, 03:44 PM   #3 (permalink)
New Gen Guru
sujoyp's Avatar
I know about them but never used them...I have put original hacked CFW few times but never a custom made..
Soo I want some advices...or else will bear the burden for 2-3 more months
Photography Gears -
Old 22-06-2011, 07:04 PM   #4 (permalink)
baccilus's Avatar
I didn't know anything about these. I will try this on my Nokia 5800
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
baccilus is offline   Reply With Quote
Old 23-06-2011, 08:42 AM   #5 (permalink)
New Gen Guru
sujoyp's Avatar
opps If someone confused it with Samsung I5800 then I am sorry I was talking about nokia 5800
Photography Gears -
Old 23-06-2011, 09:50 AM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^ try it, they are amazing. Speed gain = double
Conversations integrate(thread sms)
C6's great gallery (gallery loading of 100 pics takes 1 second including thumbnails, for first time)
Everything EXTREMELY FAST RUNNING
Old 23-06-2011, 01:01 PM   #7 (permalink)
New Gen Guru
sujoyp's Avatar
ok but I have heard that some of the functionality suffer ...and bugs??
Thats the reason I was asking ...anyways I will search ...I have seen many on dailymobile form
Photography Gears -
Old 23-06-2011, 06:20 PM   #8 (permalink)
baccilus's Avatar
Too many choices are confusing me. Can anyone suggest me the best Flashing method for the Nokia 5800 and also the best CFW. By best I mean stable and useful.
The Photon CFW requires some different flashing method which I haven't been able to understand. It has specifically asked not to use the Naviferm(or whatever?) but hasn't told anything about how to use the alternative.
Old 23-06-2011, 11:09 PM   #9 (permalink)
Manchester United <3
Ishu Gupta's Avatar
I'm using C6 RM-612 V40.0.021 ported to 5800 by mara- [Language packs added] ATM
Check these
[GUIDE] Flashing your phone with a CFW (Full Video and Text tutorial)
All Mods for CFW | for Nokia 5800 v50 & v40 and other S60v5 devices
Symbian Modding Guide For Newbies [Updated]
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 24-06-2011, 12:09 AM   #10 (permalink)
New Gen Guru
sujoyp's Avatar
Thank You Ishu Gupta....very helpful
Photography Gears -
Old 24-06-2011, 12:51 AM   #11 (permalink)
Ishu Gupta's Avatar
You need core files
C6 V20.0.041 Firmware ported to Nokia 5800 V52.0.007 Fully Working
You're welcome.
Old 24-06-2011, 07:43 AM   #12 (permalink)
baccilus's Avatar
Thank you Ishu
Old 24-06-2011, 10:09 AM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Flashing easy as cake:
[Tutorial] How to flash with 3 files (C00, rofs2 and uda)
Old 24-06-2011, 05:32 PM   #14 (permalink)
Project Halcyon V2.0
tkin's Avatar
I think I'll try them out, one question, if I kill my phone when burning can I recover it? Or do I need to go to a service center?
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline   Reply With Quote
Old 24-06-2011, 05:38 PM   #15 (permalink)
Ishu Gupta's Avatar
Flash again with a clean firmware and it'll be fine.
Do not downgrade you firmware though.
Old 24-06-2011, 09:02 PM   #16 (permalink)
tkin's Avatar
Can I upgrade to parallel firmware? I mean modded 52.xx to another modded 52.xx? Same version, no downgrading.
PS: Give me a link to the best firmware you ever used, I need looks as well speed, default 5800 firmware is slower than my father's 800/- phone.
Old 24-06-2011, 09:10 PM   #17 (permalink)
Ishu Gupta's Avatar
Yep
Nokia 5800,5530,523x,X6 - Photon C6-03 - The Fastest Firmware - Final Released!
Nokia 523X|5800|5530|X6-Fastest Firmware Ever-Phantom^2™C6 Based{Variant Added}
I'm using this one now. Its much faster than the default (60MB+ free RAM and 75MB+ free C: )
Old 24-06-2011, 09:22 PM   #18 (permalink)
tkin's Avatar
Thanks, I'll try it out soon.
Old 24-06-2011, 10:41 PM   #19 (permalink)
baccilus's Avatar
Yes the default Firmware on Nokia 5800 is very slow. But I haven't been able to find installation tutorials specifically for Photon c6-03.
This is the part that is confusing me:
Use PNHT's C6 Firmware CORE file with my CFW file and not NAVIFIRM files
I will have to use Naviform to install PNHT's c6 Firmware or is there some other software to do that?
And what will happen to my contacts and Notes after I apply the Photon CFW. Will I be able to get them back through the Nokia Ovi suite installed and synchronized on my PC?
Old 24-06-2011, 11:42 PM   #20 (permalink)
New Gen Guru
sujoyp's Avatar
I too searched soo many firmware and even downloaded my own from nevifirm...but now confused...will do this flashing on sunday
Photography Gears -
Old 25-06-2011, 12:17 AM   #21 (permalink)
Ishu Gupta's Avatar
1) DL C6 V20.0.041 Firmware ported to Nokia 5800 V52.0.007 Fully Working and extract files to C:\Program Files\Nokia\phoenix\products\RM-XXX\
2) 3. Download and Install PKEY Emulator and J.A.F (Google them)
3) Run PKEY Emulator
4) Click OK
5) Ignore the error and click OK
6) Go to 'bb5'tab and Tick - Manual Flash, Dead USB, Normal mode, Untick - 'CRT 308'
7) Tick 'USE INI and Select your phone and appropriate RM from the list (RM can be found in device update)
8) Turn OFF your phone and connect it to the computer via USB
9) Click on flash. Click OK
10) Press (and not hold) the power button when asked by the program.
11) wait.
12) Done
This will install the default C6 FW.
If you want to install any other FW (like photon etc) then DL the CFW files and put them in the C:\Program Files\Nokia\phoenix\products\RM-XXX\ folder.
Rename if necessary
Use the backup thing in File Manager.
Old 25-06-2011, 06:55 AM   #22 (permalink)
baccilus's Avatar
Thank you so much Ico . I will backup using the file manager and then copy the backup folder on my PC just to be sure.
Old 25-06-2011, 07:38 AM   #23 (permalink)
New Gen Guru
sujoyp's Avatar
@Ishu Gupta thanks...will try in evening....u made it soo easy
Photography Gears -
Old 25-06-2011, 09:57 AM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I would recommend the Phantom^1 FW, best ever I've used. It's a tweaked Photon C6-03.
Now avoid Photon C6-03 it gives less than 20 hours battery backup with minimal usage, Phantom^1 on the other hard lasts 2 days easily.
Old 25-06-2011, 10:20 AM   #25 (permalink)
New Gen Guru
sujoyp's Avatar
Thanks will remember this
Photography Gears -
Old 25-06-2011, 04:00 PM   #26 (permalink)
baccilus's Avatar
Can you post a link please. Thanks. I was gonna install Photon c6-03 but am reconsidering now.
Old 25-06-2011, 05:05 PM   #27 (permalink)
Ishu Gupta's Avatar
I have given the link to Phantom^2 in post #17.
If you want ^1
http://forum.dailymobile.se/index.php?topic=46650.0
Old 25-06-2011, 05:44 PM   #28 (permalink)
baccilus's Avatar
@Ishu: Phantom^2 has removed podcasting. But I use that feature a lot.Will I be able to add that later?
Old 25-06-2011, 05:55 PM   #29 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^ I dunno. But Phantom^2 has **** load more bugs than Phantom^1.
Currently I'm using Infinity-01 and it's amazing. Waiting for 2(should come next month)
Old 25-06-2011, 05:57 PM   #30 (permalink)
Ishu Gupta's Avatar
Yes .
