I OWN A LG G1600 AHNDSET. THE RINGTONE SOUND IS VERY LOW. IT HAS 5 RINGING LEVELS BUT AT 4TH RINGING LEVEL(2ND HIGHEST) SOUND IS JUST AUDIBLE AND AT 3RD LEVEL WE HAVE TO GET THE SET CLOSE TO OUR FACE TO HEAR.I JUDGE THE INCOMING CALLS FRM THE VIBRATING ALERT. BUT THE MESSAGE TONE IS VERY CLEAR AND QUITE LOUD. IS THERE ANY SOLUTION TO MY PROBLEM.. ONCE I HAD SIMILAR PROBLEM WITH NOKIA 2100 BUT I OPENED THE BODY AND REMOVED THE PLASTIC ON THE INSIDE OF THE BODY WHERE SPEAKER IS AND THAT SOLVED MY PROBLEM.
I USE A HUTCH (RS.99) PREPAID CARD.I HAVE ENABLED GPRS,MMS AND HUTCHWORLD. MY FRIEND USES THE SAME CARD IN A NOKIA 3100. HE SENDS ME BOOKMARKS BUT I DONT GET IT. COSTUMER CARE TOLD THAT MAYBE MY INBOX IS FULL CREATING THE PROBLEM BUT MY INBOX AND OUTBOX ARE EMPTY.WHAT COULD BE THE POSSIBLE REASON AND HOW CAN THE PROB. BE RECTIFIED.
MY PHONE HAS NO INFRARED AND BLUETOOTH. SOMEONE TOLD ME THAT INFRARED AND BLUETOOTH KITS ARE AVAILABLE IN THE MARKET. I THINK MY HANDSETS MEMORY IS ONLY 1 MB SO IS THERE ANY USE OF GETTING A BLUETOOTH OR INFRARED KIT. ? I ,BUT, WANT TO SHARE RINGTONES, PICTURES, SCREENSAVERS, ETC. SHOULD I GET ONE ?
