Old 31-05-2011, 07:02 PM   #1 (permalink)
Question ear-phones below INR 1000
hi all!
i need to buy earphones, to be used with X2-01 and 5233 mostly.
budget: under 1000
it should have good bass!
I need your valuable suggestions. thanks in advance.
regards.
Amit Dutt
amit dutt is offline   Reply With Quote
Old 01-06-2011, 01:46 PM   #2 (permalink)
v4u_luv2004's Avatar
Default Re: ear-phones below INR 1000
Dude go for Creative EP 630
You won't get anything better at this price range.
It will cost you less than Rs 800
Can order from ebay also they are selling for around 750 or something.
v4u_luv2004 is offline   Reply With Quote
Old 01-06-2011, 01:55 PM   #3 (permalink)
its 729 @letsbuy
but cn get it for less
pm me fr tht bcz i nt sure if postin links is allowed here
can get it for 600
or try soundmagic pl 11 or 21
raj_in is online now   Reply With Quote
Old 01-06-2011, 02:02 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Originally Posted by amit dutt View Post
hi all!
budget: under 1000
regards.
Get Soundmagic PL21 or PL30. Much much better than shitty EP-630. Also check Sony MDR-EX50LP.
desiibond is offline   Reply With Quote
Old 01-06-2011, 02:07 PM   #5 (permalink)
Manc
xtremevicky's Avatar
Soundmagic PL21-30 or Ex50LP.
If you only want bass then Creative EP 830 .
If you like the Post , There is a Rep Button ,
If not then Understand that, There are people with different Opinions !
xtremevicky is offline   Reply With Quote
Old 01-06-2011, 03:42 PM   #6 (permalink)
I own EP630.
Sound amplification is awesome.
Bass is superb.
Due to vacuum created by it Noise Reduction is proficient.
But dude it lags behinds when it comes to Surround sound.
Plus it sounds irritating in comparatively poor music quality often when you listen to heavy metal music.
So make your own decision in this range it gives satisfactory performance.
nixhead is offline   Reply With Quote
Old 05-06-2011, 09:08 PM   #7 (permalink)
Soumik's Avatar
Not exactly related, but i have a similar need. How would you rate a Soundmagic PL30 vs PL50? Its almost double the price, but is it worth it? And is there any alternative to PL50 in the same range?
Soumik is online now   Reply With Quote
