Old 18-05-2011, 01:35 PM   #1 (permalink)
coolnikhil's Avatar
Lightbulb Best Mobile under 15-17K bucks
hie...
I am looking for a fone within 15,000 to 17,000 bucks..
I want to use my fone generally for messaging around 350 messages a day.
and around 2 hours of net surfing and 5-6 hours of music..
plz anyone suggest me a good fone, android would be preferable.
Thanks in advance...
coolnikhil is offline   Reply With Quote
Old 18-05-2011, 01:39 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Best Mobile under 15-17K bucks
if you can slightly increase the budget, check Samsung Galaxy SL.
desiibond is offline   Reply With Quote
Old 18-05-2011, 02:48 PM   #3 (permalink)
da Mafia
350 messages so do you prefer touch screen or qwerty one
dsneih is offline   Reply With Quote
Old 18-05-2011, 03:21 PM   #4 (permalink)
coolnikhil's Avatar
anything will work.... i m currently using Nokia 5233.
Old 18-05-2011, 03:38 PM   #5 (permalink)
da Mafia
Galexy SL is best if you can stretch your budget ...
Old 18-05-2011, 03:41 PM   #6 (permalink)
Excessive happiness
furious_gamer's Avatar
Increase your budget by 2k and get Galaxy SL. Otherwise get Samsung Ace, Moto Defy
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now   Reply With Quote
Old 18-05-2011, 03:43 PM   #7 (permalink)
Believe Me or Not!!!
Yup, go for Galaxy SL. A bigger screen is always better than smaller one when it comes to onscreen keyboard.
NainO is offline   Reply With Quote
Old 21-05-2011, 02:10 PM   #8 (permalink)
FUBAR.
KDroid's Avatar
Smile Re: Best Mobile under 15-17K bucks
Go for Galaxy SL... If you can't, Go for Motorola Defy. Check both of them out!
If you are to choose from Ace & Defy, go for Ace blindly.
As for texting, a phone with a qwerty keypad should be preferred... and Motorola Milestone is just perfect for your use. It is also one of the thinnest QWERTY sliders around.
If Milestone exceeds your budget, check out Motorola Backflip.
Inactive. For a year.
Twitter
KDroid is offline   Reply With Quote
Old 21-05-2011, 02:25 PM   #9 (permalink)
milestone & backflip are just too old & H/W is slow. yes they can get the word done but if OP can wait, he may get SE Xperia Mini Pro. though it may be out of his budget at launch.
Old 21-05-2011, 02:40 PM   #10 (permalink)
FUBAR.
KDroid's Avatar
What if it is old, Milestone is still lot better than many of the phones around.
Milestone has got great reviews.. and I have never came across a line that claims its H/W to be slow.
SE Xperia mini pro can be bought for around 12k these days... and better models are available in the range he has specified.
Milestone is 5x better than Xperia Mini Pro.
Twitter
