Results 451 to 480 of 554
Thread: Motorola Defy and Defy+
15-11-2011, 01:00 AM #451Right Off the Assembly Line
- Join Date
- Jul 2011
- Posts
- 22
15-11-2011, 03:51 PM #452Right Off the Assembly Line
- Join Date
- Aug 2011
- Posts
- 7
re: Motorola Defy and Defy+
ICS is out at last
check this out Android 4.0 Ice Cream Sandwich source code is now officially available
Waiting for roms
16-11-2011, 09:50 AM #453
First Rom for Defy based on ICS is here - Galnet A Modified MIUI Experience! » ICS BUILDS
AMD phenom x2-555 BE
Asus M2N68 AM3 board
2x2 GB Corsair DDR3-1333
Sapphire Ati Radeon 4670
Samsung Syncmaster P2250
Windows 7 Ultimate x64
16-11-2011, 10:54 PM #454Right Off the Assembly Line
- Join Date
- Jul 2011
- Posts
- 6
17-11-2011, 01:11 PM #455
17-11-2011, 05:51 PM #456Right Off the Assembly Line
- Join Date
- Jul 2011
- Posts
- 6
17-11-2011, 07:21 PM #457
18-11-2011, 06:41 PM #458In The Zone
- Join Date
- Mar 2009
- Location
- Chennai
- Posts
- 369
having some issues with defy..
#My dialer kept freezing occassionally on cm7. (was annoying while making important calls).
So installed WajkIUI. Here, scrolling between the home screens lagged heavily.
I tried almost all launchers but no use. Even scrolling apps in appdrawer lagged. Settings menu, conversation list in messaging app, contacts etc . everything lagged..
But the Quadrant score remained around 2000 @ 1GHz. But whats the use ?
After an hour of frustration, I installed CMIUIv2.4 and the case is same .. Every little thing lags..
How come it is good for rest of you people ?
Does my defy has any peculiar problem ?
and i'm not ready to settle with stock rom.
Pls help guys..Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB + WD Caviar Green 500GB|Logitech MK250|CM Elite 310|CM EVO 212|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|Motorola Defy + Nokia 101
18-11-2011, 11:33 PM #459Broken In
- Join Date
- Mar 2011
- Posts
- 153
19-11-2011, 01:52 PM #460In The Zone
- Join Date
- Mar 2009
- Location
- Chennai
- Posts
- 369
^^ for miui roms there is no need of changing the sbf.
You just got to be in froyo before you install them (for optimum performance).
and yes i wiped cache..Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB + WD Caviar Green 500GB|Logitech MK250|CM Elite 310|CM EVO 212|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|Motorola Defy + Nokia 101
19-11-2011, 11:03 PM #461Broken In
- Join Date
- Mar 2011
- Posts
- 153
20-11-2011, 01:07 AM #462
Thats strange really... :O
I just installed this week's WIUI, and after a few hiccups which occur dring a new rom installation for me...(stuck in boot loop, continuous force closes, etc), i have it full up and running done battery calibration, everything's fine... no lags waht so ever. Using default launcher.. of WIUI.
did u wipe data, cache and dalvik cache before and after the installation? moved everything to sd card through titanium back up... and restarted in between 2-3 times?
*wipe data, cache and dalvik cache before install and cache and dalvik after install
20-11-2011, 04:02 PM #463In The Zone
- Join Date
- Mar 2009
- Location
- Chennai
- Posts
- 369
^^yes i did them..
nothing helped.
Tried LiquidArc rom... It is so so good. No lag in any of the above specified places.
Quadrant score 2085 @ 800Mhz..
No freezing of dialer.(so far).
Battery life - 20hrs at moderate usage. (its ok i can adjust
No rom handles Live wallpapers.. It was one of the thing i was dreaming about while getting defy.. Very much disappointed. The cheap galaxy Y handles live wallpaper like breeze.. :-/Phenom II X6 1055T|Gigabyte 880GM-USB3|Transcend 4GB DDR3 1333MHz| Benq G2220HD|PowerColor Radeon HD5770|Seagate 500GB + WD Caviar Green 500GB|Logitech MK250|CM Elite 310|CM EVO 212|Zebronics Pro 600w|Creative A100 2.1 speakers|LG DVD|Motorola Defy + Nokia 101
01-12-2011, 10:27 AM #464
A smartphone is as smart as you are!
Motorola Defy with WJUI
02-12-2011, 03:28 PM #465
Thats by JBoogie rite? Its not been updated since a looong time
. But since it claims to be lighter than CM7, it should be the faster than anything else. How long does the battery last in this ROM?
03-12-2011, 11:10 AM #466
03-12-2011, 05:40 PM #467Right Off the Assembly Line
- Join Date
- Nov 2011
- Posts
- 41
Any Defy owners using Gps navigation like MMI on Defy ? How is accuracy ? Does it work smoothly ? Any issues ? How about battery life while using it for navigation.
Note : I am asking about gps not A-gps with data plans.
05-12-2011, 12:03 AM #468Right Off the Assembly Line
- Join Date
- Jul 2011
- Posts
- 22
I ported to cyanogenmod 7.1
It doesn't freezes like stock
Does anybody know to get dialler of stock defy(2.2)
Thanks in advance
hi,
last day i flashed cyanogen 7.1 stable mod for defy.
it was working nicely
later on i wiped the system and and installed the backup of stock 2.2.2 using clockworkmod recovery, it also worked without any problems
again i wiped the system cache and installed cyanogen again ,but this time i got stuck at the cyanogen logo which comes in loop, so i flashed again but no positive
after that i entered into recovery mod and cleared the system cache and data
after this i got stuck at google logo,(still able to enter into default recovery mod, but i cannot enter into bootloader)
plz help urgently
thanks
05-12-2011, 09:32 AM #469
05-12-2011, 10:52 AM #470Right Off the Assembly Line
- Join Date
- Jul 2011
- Posts
- 22
05-12-2011, 07:35 PM #471
07-12-2011, 04:52 PM #472Broken In
- Join Date
- Jun 2010
- Posts
- 113
I want to buy defy, where can i get it in 13k range ?
Core i7 950 | Asus Sabertooth X58 | Corsair DDR-III 6 GB | Sapphire HD 5670 512MB GDDR5 | CoolerMaster 650W SMPS | Thermaltake VJ400G1N2Z | BenQ V2410 | AVerTV Volar Go M A833M | Sennheiser HD 202
Games: BF3 & TF2 (Best Game) | CS GO | Saint Row 3 | Skyrim | Dota 2 | World Of Tanks | LOL | Arma 2 Free | GTA EFLC (Hate DRM, last GTA purchase)
08-12-2011, 09:35 AM #473
hey guys can i get a used defy under 9k . . Please reply. . I also want to be a defy owner . Otherwise i have to get dell xcd35
reply
CM 7.2 RC0 (KANG) on ZTE blade. @787mhz governor ondemand......
08-12-2011, 06:12 PM #474
@kamal_saran & chris, pls check the sticky threads for mobile price....and it is definitely much better than xcd35
12-12-2011, 12:15 PM #475
@chris: You may get the defy for 13k at local shops if u drive a good bargain, again they should be having the stocks left as the defy + is now flooding the market..
12-12-2011, 04:55 PM #476
Anyone tried the new "AOSP/CM9" Experimental Builds for the Defy in XDA?
09-01-2012, 08:35 PM #477
installed liquidearc ginger over stock rom (not nordic one) everything ok, but getting heavy issues on gallery only, it keeps hanging, force closing, laggy.. trying the inbuilt SE launcher, but i guess I will revert back to ADW launcher Ex soon
My mobile phone battery runs out all the time because all the messages come straight to me.
10-01-2012, 06:53 AM #478
^^Clean cache and dalvic cache.
Macbook Air 11"2011,Iphone 4S 16GB,Ipad2,Sennheiser HD-25 1-II,HD650,FiiO(E11,E17...yeh! I know!I need an upgrade)
10-01-2012, 07:05 PM #479
14-01-2012, 10:29 PM #480
Better get rid of the gallery completely and install quickpic.
Motorola defy plus 13,990 on ebay
By eprasu in forum Mobiles and TabletsReplies: 2Last Post: 28-02-2012, 09:38 PM -
Should i buy Motorola Defy+ from Flipkart?
By prantik007 in forum Mobiles and TabletsReplies: 19Last Post: 18-02-2012, 08:10 PM -
Where to get Motorola Defy ?
By atherq in forum Mobiles and TabletsReplies: 6Last Post: 17-11-2011, 09:16 PM -
Motorola Defy in Licorice
By rohit18rs in forum Mobiles and TabletsReplies: 1Last Post: 18-10-2011, 11:36 PM -
Motorola Defy vs Desire
By umangkedia in forum Mobiles and TabletsReplies: 18Last Post: 15-05-2011, 04:23 PM
LinkBack URL
About LinkBacks
