Old 26-04-2011, 05:35 PM   #1 (permalink)
Living to Succeed
ajayashish's Avatar
Default Vodafone Mobile Connect
hi,
I need help from someone using Vodafone mobile connect.
I am using Samsung Omnia B7610 set which has a Windows 6.5 version installed.
I was using Vodafone Live service and had to use some proxy setting to use the web browser. I was not able to use applications which need a data connection and they were unable to go through proxy settings.
I read at Vodafone site that with Vodafone Mobile Connect we can connect to all websites and even use web applications as it dont use any proxy settings.
I have enabled it but internet is not working. Has anyone configured it on their windows handset then pls help. I have done the manual settings and it looks exactly same as it is recommended. But still not working.
PLS HELP
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline   Reply With Quote
Old 27-04-2011, 02:55 PM   #2 (permalink)
Default Re: Vodafone Mobile Connect
Maybe its not yet activated. The access point you need to use is 'www'
So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
drumster is offline   Reply With Quote
Old 27-04-2011, 03:15 PM   #3 (permalink)
OK use the following settings to maually create a Acess Point-
Connection Name- Voda www
Data Bearer- GPRS
Acess Point name- www
Username- (leave it blank)
Authentication- Normal
Homepage- use any
Old 27-04-2011, 03:57 PM   #4 (permalink)
Living to Succeed
ajayashish's Avatar
Thanks guys... got it and its working
