Mobiles and TabletsTopics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries.
I would suggest nokia 2700cc using it for around 6 months good phone average camera but then u can't get a superb camera in this budget ( street price <= 3000)
What about nokia C2-01.
Its a very good one with 3G and 3.2MP Camera. Its just around 3.8k.
Also look for some Samsung GURU models with dual sim and good battery.
I won't comment on C2-01
but i own samsung metro 3500i bought it for 4.1 k
Look how good it is ( these cons are applicable on almost on all samsung phone under 5k)
1) won't run jar need jad file also
2) won't run file > 500kb
3) poor battery backup even an android phone will put it to shame
4) won't allow installing app on memory card
5) limited memory for installing app
6) Delicate had to replace its ear speaker within 6 months ( Thank God it was in warranty)
7)if u use jar to jad maker it will not accept jad file 90% of all the times u try
8)worst inbuilt browser i have used *( despite i in 3500i for internet)
9)long pressing 0 won't do anything (WTH!!!)
10) will post more once i remember more
OT:-
saswat u should change hdd 500 tb to 500 pb(petabyte)
Keypad of nokia 2700 is hard & 2730 keypad is odd. Its like having keys covered by plastic skin. Also battery backup is not good under heavy use. Rest everything is good. However samsung have app problem. Size, type, etc. you ask it, they'll have it. But battery backup is best & are really light & look trendy.
Cedar has more talktime, better internet speed(3G), good audio, good video recording(320x240) C2-1 has higher resolution camera(3.2MP), better battery(1050mAh vs. 1000mAh) but miserable screen, very bad viewing angle, poor audio reproduction quality.
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
Thanks for ur help Guys....
Bought SE Cedar-4.9K for my aunt, she loved it..
can you try opening a MS-office or pdf file in ur aunt's phone??
