Originally Posted by reddead
i tried to put up a new gingerbeard theme on my i5801[galaxy 3] but did something wrong and now my phone is stuck at boot screen....
i need help in reflashing my phone....
i had 2.1 stock and now i am thinking of flashing with 2.2 or other rom??[suggestions needed]
you followed the procedure given in XDA? if yes, it states that Gingerbread theme is for G3 running Android 2.2 only. look
here.
well as there no other option, try install Froyo or you can go for some custom Gingerbread roms (if avl).
i read that you need to factory reset before flashing??i cant even start my phone,how to factory reset??
links needed for complete guide to falshing for noob
and also links for the 2.2 rom for i5801??
pls help guys!!!
you are stuck. can't factory reset mobile. so forget it. install a custom rom straightway. also if you are new to Android, you really should have asked for some guide or backup plan before taking such an odd step.
Originally Posted by AndroidFan
Boot into Custom Recovery... On my LG Optimus One, I have Nandroid. Do you have the same custom recovery on your phone?
From custom recovery, you can reflash your phone easily...
they don't have Custom Recovery. but may try clockworkmod recovery. but most use a PC software. can't remember the name. some opin or so.
i see you already have created a thread in XDA about your problem:
need urget help!! stuck at bootscreen
