Old 31-03-2011, 05:21 PM   #1 (permalink)
Default Any phone around 12K or less
Hi,
I want a phone with a feature to delete multiple msg's. I use it for the business & there is no way to stop annoying msg's, so it should be easy to delete multiple msg's for good.
Wish there was a feature like in gmail select then shift+select the end & delete :-P
Ajit
neo420 is offline   Reply With Quote
Old 31-03-2011, 05:45 PM   #2 (permalink)
Default Re: Any phone around 12K or less
^^ Get an LG Optimus One.
There should be plenty of apps to delete (or even block) messages to your phone.
pauldmps is offline   Reply With Quote
Old 31-03-2011, 06:25 PM   #3 (permalink)
At this price range, there is only one de-facto choice
LG Optimus One.
Android Froyo, 600 mhz proccy(you can OC to 700 mhz)
and yes there will be plenty of apps to block and delete muptiple SMS's from Android Market place.
Old 31-03-2011, 06:51 PM   #4 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Can anyone please list free or cheap Android apps that can be used to block phone calls and messages from selected numbers? Anything similar to iBlacklist?
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 31-03-2011, 06:54 PM   #5 (permalink)
Thx for the reply guys... I'll look into this model. I went thru the LG apps site & not much description of the apps thr, guess we gotta try n chk.
Old 31-03-2011, 07:04 PM   #6 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Its an Android smartphone. You don't have to depend on already-present apps. Check https://market.android.com for all the apps available (more than 100,000 apps)
--- George Carlin
Old 31-03-2011, 07:53 PM   #7 (permalink)
Try this page-
How to Block calls and messages on Android Phone | Google Android
Old 31-03-2011, 08:43 PM   #8 (permalink)
@neo420, if you are a business user, i think you'll prefer a H/W keyboard. look for Galaxy 551. but if you are comfortable with a onscreen QWERTY (test it once), get Optimus One. its the best in its class.
Sam is offline   Reply With Quote
Old 31-03-2011, 09:01 PM   #9 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Originally Posted by thetechfreak View Post
Thank you very much friend...
Cheers!
--- George Carlin
Old 31-03-2011, 10:16 PM   #10 (permalink)
Gadget gyan dispenser
What is with everyone here....since when does a business user's best recommendation was an Android in the lower range.....seriously ......there are other better devices for OP's requirements....For business usage ...a full touch screen device.....not even a one with a keyboard......
Think Blackberry,Nokia and everyone else must close down and make only full touch devices like HTC,Samsung
@OP
android is still not the best bet for a business user...there are other devices not on android which are better at what android can provide(not in the apps section but regarding the core functionalities like quick messaging,email,security and not much tough on the h/w)....except the apps...which are not required a lot for a business user.....
Acc to your requirements and budget i would recommend a Nokia E71...
On the lower end one can get a qwerty Nokia C3 @5.5k but that is not buisness specific.....more for social networking....
Also Blackberry Curve 8520 @9.9k is also highly recommended
although all phones nowadays have the basic sms/communications req(including yours i.e mark unmark messages and delete) covered....many free symbian apps are available for specific functionalities
@Others
Don't you think android will be too much for the stated req and also why complicate matters right.....
One thing everyone neglected was durability and toughness of the device...O1 will shatter into pieces if used roughly.....whereas E71 has gun metal back.....also using E71 is easier as compared to an O1(android that is for a newbie)...too much unnecessary complications is what can be said for android......also android was not designed for business users i.e why it does not have any devices to give to the public....
people recommending O1 to a business user is an even bigger joke.....than android's business devices...
p>S:consider the requirements first before recommending
aakashdave11 is offline   Reply With Quote
Old 01-04-2011, 07:36 AM   #11 (permalink)
Please suggest some apps to block unnecessary sms & calls.
And for buisness, he doesn't mean that he'll be using BB services or MS Office. He just wants to block unnecessary calls & messages. That's it.
You just find it amusing to contradict us & have a fight in every thread. That is why you go on posting nonsense in every thread.
Old 01-04-2011, 07:51 AM   #12 (permalink)
whereas E71 has gun
for a newbie)..
Lava A10 also has Gun metal back. How many people will you reccomend that phone.
Ok S60 maybe a little easier to use but it doesnt have 300,000 apps like O1
Use Android phone for couple of days and everything will become easy.
Is camera quality of E71 comparable to O1?
Does E71 support Augmented Reality like O1?
Can E71 be turned into Wi-Fi hotspot like O1?
Old 01-04-2011, 01:01 PM   #13 (permalink)
@paul
dude don't try to start a fight with me in every thread ..help the OP instead...i am not contradicting...many a times i recommended O1 but here other phones are better.....
@techfreak
Have you ever used Lava A10....UI is not usable as it is copied from a chinese knockoff....
OP does not need those apps...his req is simple and specific....also app count does not define a good Buisness phone....
It is better and has a flash with autofocus........compare results and talk
Again Not needed by OP...do you even read before posting...
Guys was this mentioned.....this is not a core business functionality niether mentioned by OP.....but can be done yes.....
here
p>S:i would also want to suggest the newer Nokia E5...5mp camera with LED..beats O1...sans android.....links below.....Now what say you!
Nokia E5 - Full phone specifications
Old 01-04-2011, 03:16 PM   #14 (permalink)
Believe Me or Not!!!
+1 for E5
NainO is offline   Reply With Quote
Old 01-04-2011, 03:30 PM   #15 (permalink)
Hey man.....it may catch anyones fancy to try something new rather than the oridary over and over again so AR might be used by OP. Ofcourse this OP doesnt need it but you may never know in long run...
If anyone just wanted a phone for things they wanted(eg A multimedia phone that can play music and just about take photos / vids) then there would'nt have been Android.
Nokia would have probably had 90% market share upto now and iPhone wouldnt have made it past the assembly line.
So its time to move on and reccomend new devices rather than going on and on with old stuff.
I stand by my reccomendation for Optimus One. It can do umpteen number of things that E71 can't even dream of.
Ofcourse, you might say "Business Phone-Business Phone-Business Phone" but Optimus One if great.
No more fighting please. Lets just wait and see what OP buys.
Old 01-04-2011, 04:43 PM   #16 (permalink)
How do you know that ? You are not the OP.
The OP did not ask for a business phone. The OP mentioned that he wants it to block calls & sms when he is working (at the Business). He just asked for a phone which can block unnecessary calls & sms. And since Android has a lot of apps to do that, O1 is the best suggestion.
Old 01-04-2011, 06:02 PM   #17 (permalink)
From this i get that the person will be using his phone when working right....he might also want do some work on his phone then...not just block sms/mails
...for that he needs a buisness device........for basic need qwerty is helpful and acc to me an O1 will not do...
yes android has many apps for blocking unwanted msg's.....but most of the devices Nokia/BB have these basic features or have a software for that.....
Old 01-04-2011, 06:28 PM   #18 (permalink)
^^ I want you to name some apps for Symbian for that.
And suggest a BB under 10k please.
Old 01-04-2011, 10:10 PM   #19 (permalink)
^^^ For call/sms app, google them. Some results are - advanced call manager, mCleaner etc.
It's symbian, once it was famous for its application availability. With android gaining a good grip on market, it doesnt mean that all support for symbian gonna vanish.
Rest is upto OP
Old 01-04-2011, 10:23 PM   #20 (permalink)
get a grip is what i can say....before android was even born...i,e just 2-3yrs from now.....symbian was the best open source platform available...so don't worry about apps.....
Also curve is available for 10990/-.....it is a good phone to own.....for a buisness user...
p>S: droid fans what can i say....google has a search engine also.......
Old 01-04-2011, 10:43 PM   #21 (permalink)
This sentence proves the fact that Symbian is NOT the best Open source platform presently and has a succesor.
As you said Google has a search engine that engine showed that E71 has 369 mhz proccesor.
Optimus One has 600 mhz proccesor which is 1.62 times faster than E71
A faster proccesor means Optimus One is better in multi-tasking.
Old 01-04-2011, 11:09 PM   #22 (permalink)
^^^ that's why I suggested Nokia E5, it too has 600 MHz processor.
Old 01-04-2011, 11:13 PM   #23 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Friend, you are an Android user. You know O1 is better than E5 when it comes to content consumption. E5 is really handicapped in many ways. Few good things about it are physical qwerty and good battery life.
Still, O1 Rulez!
--- George Carlin
Old 01-04-2011, 11:38 PM   #24 (permalink)
Buddy, I just provided him with an extra option which serves his requirements
It's upto OP to make his desicion between - touchscreen and qwerty.
Old 05-04-2011, 09:50 PM   #25 (permalink)
btw
Nokia E5 8990/-
BB curve 9500/-
O1 10225/-
source :ebay
choose wisely.....
