Old 31-03-2011, 09:09 AM   #1 (permalink)
motobuntu's Avatar
Default Help! recovering contacts from Nokia 5130
Guys, My sisters Nokia 5130 was getting hanged within 30-40 seconds after booting. As she has more than 5000 messgaes in her inbox, I thought that may be the cause of the problem, so I reset the phone to factory defaults.
Which solved the issue, but all the contacts from the phone has been deleted. Now, is there any way to recover the deleted contacts. Any help on this would be highly appreciated.
A computer once beat me at chess, but it was no match for me at kick boxing.
motobuntu is offline   Reply With Quote
Old 31-03-2011, 09:48 AM   #2 (permalink)
Default Re: Help! recovering contacts from Nokia 5130
^^ Factory reset does not delete contacts in S40 as far as I know. Try changing the default memory settings in contact menu.
pauldmps is offline   Reply With Quote
Old 31-03-2011, 10:39 AM   #3 (permalink)
I don't think theres a way unless you back up'ed the contacts or have a separate copy in the memory card. Sorry.
If she has 5000 SMS's then a phone like that is bound to hang....
You should have emptied the inbox rather than "Factory resetting:" of a phone..
WEll, contacts might be saved in SIM card
Old 31-03-2011, 11:32 AM   #4 (permalink)
motobuntu's Avatar
Yes, you are right it only changed the memory location to phone. You saved me.
Old 31-03-2011, 11:53 AM   #5 (permalink)
Good Job!
Try not to keep 5000 SMS again
Old 01-04-2011, 05:25 PM   #6 (permalink)
motobuntu's Avatar
^^ Yes, I will never do that again.
