Old 22-03-2011, 11:43 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Chetan1991's Avatar
Default Does larger microsd card slows down access speed in mobiles?
Does using an 8gb microSDHC card slows down file access speed in comparison to using a 4gb one?
Im going to buy an android mob and wouldn't want to see videos stuttering, but 4 gb seems rather small. What would be better: a single 8gb card, or 2 4gb cards?
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline   Reply With Quote
Old 22-03-2011, 12:14 PM   #2 (permalink)
Default Re: Does larger microsd card slows down access speed in mobiles?
8gb class 6-8. also depends on platform & what file it contains.
Sam is offline   Reply With Quote
Old 22-03-2011, 12:25 PM   #3 (permalink)
Chetan1991's Avatar
You didn't answered the first q.
BTW, are you a girl?
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
LG Optimus One P500
Old 22-03-2011, 06:18 PM   #4 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Go for an 8 GB card. I have a new Optimus One phone... modded. Have no pictures, videos or mp3s yet... and very few apps. But my 2 GB SD card (which comes with the phone) is 75% full already. A bunch of space is used by ext4 partition to install the mod and nandroid system recovery and backup.
Buy as large a card as you can afford. Because if you mod, you cannot just swipe in a new one if the old card is full. All your apps and core OS software is on the SD card.
Cheers!
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 22-03-2011, 08:19 PM   #5 (permalink)
doesn't matter till the card is of high class.
no.
1.5Gb filled already? ext4 = 512Mb (as advised). so whats with the 1Gb? custom recovery doesn't takes up so much space.
also the DEVs told not to convert ext3 to 4 if using a low class card. did you benchmarked it?
Old 22-03-2011, 09:57 PM   #6 (permalink)
Peak Oil is real!
AndroidFan's Avatar
I didn't benchmark my card. So, don't know about class. I just followed instructions to install custom recovery, which said convery ext3 to ext4. The partition is 512 MB,
I guess a bunch of space is taken by VOID modules. I have enabled all of them.
Cheers!
--- George Carlin
Old 22-03-2011, 10:10 PM   #7 (permalink)
Any specific reason for this query ? For your information, there are no girls at TDF.
pauldmps is offline   Reply With Quote
Old 22-03-2011, 11:30 PM   #8 (permalink)
Chetan1991's Avatar
nevermind
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
LG Optimus One P500
Old 23-03-2011, 12:10 AM   #9 (permalink)
there is: me1.
Cheers!
are you using the memory card given with the mobile? well good for me. will use the stock card.
Old 23-03-2011, 09:09 AM   #10 (permalink)
Bang! Bang!
noja's Avatar
how can you use two micro sd cards at the same time
noja is offline   Reply With Quote
Old 23-03-2011, 11:15 AM   #11 (permalink)
Chetan1991's Avatar
I thought i would just swap them and use the one i needed, like cds
Hmm.. So i should buy an 8gb card of min. class 6, right?
And how to determine the class? Is the SD tools app accurate?
Could you please look at this:
http://www.thinkdigit.com/forum/ever...id-mobile.html
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
LG Optimus One P500
Old 23-03-2011, 11:20 AM   #12 (permalink)
Fullbring
Zangetsu's Avatar
Access speed depends on the proccy speed of mobile also...if the company say 16GB extendeble then they must have lab tested it with 16GB card....
access speed also depends on the "how old is the card"...coz of time degradation....
Old 23-03-2011, 01:59 PM   #13 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Just buy an 8 GB card. I don't know how much effect higher class cards would have on access speeds. O1 is an entry level phone. There are inherent limitations here... A Class 10 card might perform only as fast as a Class 4... because of hardware limits in O1. (I don't know if it happens or not)
So, just buy a card... don't worry about class just yet... I used the stock 2 GB card that came with the device and it is good enough.
Cheers!
--- George Carlin
Old 24-03-2011, 09:10 PM   #14 (permalink)
Bang! Bang!
noja's Avatar
I'm going to buy 8gb class 2 for 500 rs tomorrow. rashi douchbags had blocked the supply to inflate the price tag. too bad their trick didn't work.
Old 24-03-2011, 10:05 PM   #15 (permalink)
Chetan1991's Avatar
Aint class 2 too slow? Just 2 mbps. It might make videos stutter.
I dont think 10 mbps would be an unspported speed in o1. Its just 10mbps, internal bus is so much faster, so why wont the mob support such a small speed?
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
LG Optimus One P500
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/138327-does-larger-microsd-card-slows-down-access-speed-mobiles.html
Thread Does larger microsd card slows down access speed in mobiles? | Digit Forum | BoardReader This thread Refback 02-08-2011 09:34 AM
