Results 811 to 840 of 880
Thread: Samsung Galaxy S II
21-01-2012, 09:53 PM #811
It may sound stupid,
Is it possible to stop the stock player from auto rotating without any 3rd party app in 2.3.6?
I tried for hours but could not modify/replace the TW video apk of 2.3.6 with that of 2.3.3 fully.
Could manage to create a rotation shortcut in the player itself, but it will replace atleast one essential control button of the player!
If nothing works, I will force the player to landscape mode only, but that is the last resort.
Any help guys?
Can post the apk and framework files if any one is interested.
Sent from Galaxy S2Macbook Air 11"2011,Iphone 4S 16GB,Ipad2,Sennheiser HD-25 1-II,HD650,FiiO(E11,E17...yeh! I know!I need an upgrade)
02-04-2012, 01:06 PM #812
Re: Samsung Galaxy S II
How do I connect my SGS2 to my LED-backlit LCD TV Samsung?
02-04-2012, 05:17 PM #813
^^Use MHL Port for that!
03-04-2012, 10:59 AM #814
03-04-2012, 04:17 PM #815
03-04-2012, 04:22 PM #816
What is the latest update?2.3.6?
I am still on stock 2.3.3 , does update add any feature or improve battery life?
03-04-2012, 07:05 PM #817
Yeah better stability and much better battery life on 2.3.6.
Instead wait for the ICS upgrade, why waste time in upgrading to 2.3.6 & then to ICS again.
03-04-2012, 09:10 PM #818
Bought a second hand S2 from a friend for 20k. Currently on CM9. Feels good to be back on Android.
Super User & WebApps Stack Exchange ♦ Moderator | About me | cpgweds
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Klipsch Image S4a | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM | Nexus 4 | Hellforge - Intel Core i5 3470 | 8GB Corsair Vengeance | Gigabyte AMD 7750 | Seasonic S12II 620W | MSI ZH77A-G41 | CM690
03-04-2012, 09:28 PM #819
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
09-04-2012, 12:33 PM #820
I have Kies installed and do my updates with it. Now there is an update for kies itself and i start the update process and it downloads but when i restart kies again it again shows that an update is available for kies. So i am unable to upgrade my mobile.
What is Odin? Is it legal or offixial way to upgrade?
Will Samsung provide ICS upgrade for Indian users? These mfgs are playing too much...why cant they.ptovide upgrades as and when it becomes available...||GNU/Linux User||PCLOS KDE 4.6||17" DELL Studio||
topdocumentaryfilms.com
09-04-2012, 12:42 PM #821
♦ i7 950 ♦ SABERTOOTH X58 ♦ GTX580 ♦ 8GB RAM ♦ TX650 ♦ CM 690II ♦
♦ A 5.5" Plastic Pahblet called Galaxy Note II
09-04-2012, 01:51 PM #822Apprentice
- Join Date
- Aug 2009
- Posts
- 59
Try uninstall and reinstalling Kies.
Odin is the software used to flash ROM for Samsung mobiles in recovery mode. As long as you are flashing Stock ROMs, You are fine. No Issues with respect to Warranty, etc.
Go Here. Samsung Updates - Unofficial. Download the ICS firmware for your phone filtering Country/Region. I guess Euro firmwares with English support should do. Also as stated by the user "ithehappy" there might be Indian ICS ROM. Make sure you pick i9100 or i9100G as applicable. Flash the ROM using ODIN. Good Luck
To be satisfied with a little, is the greatest wisdom; and he that increaseth his riches, increaseth his cares; but a contented mind is a hidden treasure, and trouble findeth it not.
11-04-2012, 04:43 PM #823
I have recently purchased a White SG-2 from Grey Market for 21K. Since it was imported from UK. I am not sure if it was a locked phone which was jailborken here. But if I upgrade its firmware, will it lock it?
(Gaming Rig) Intel E8400 @ 3.6Ghz, ASUS P5Q Pro, 4GB G.Skill DDR2 800, WD 6400AAKS HDD, MSI Cyclone GTX 460, Corsair 650TX, CM 690, Dell SP2208WFP (22 inch), Windows 7 Ultimatum 64
11-04-2012, 08:37 PM #824
Can I connect my SGS2 to my Samsung LED TV D6000 series wireless?
11-04-2012, 09:51 PM #825
This may help-
AllShare
12-04-2012, 02:49 PM #826
Guys I broke the Screen for my SGS2. Any idea how much will the replacement screen cost?
12-04-2012, 05:25 PM #827
16-04-2012, 01:01 AM #828
7-7.5 to be precise, check with your retailer anyway.
Were you ...... the screen??
10-05-2012, 04:11 PM #829
Any good must have apps for SGS2?
17-05-2012, 02:03 PM #830
Guys what is wifi direct in GSII.Anyone used it?
17-05-2012, 06:53 PM #831
There are plenty mentioned in XDA.
WiFi direct on SII♦ i7 950 ♦ SABERTOOTH X58 ♦ GTX580 ♦ 8GB RAM ♦ TX650 ♦ CM 690II ♦
17-05-2012, 10:02 PM #832
i am buying one in a few days....
local shop is quoting a 26.5k...Spoiler:
19-05-2012, 01:18 AM #833
19-05-2012, 02:08 AM #834
19-05-2012, 02:37 AM #835
Till then One S will be there and most probably it will fall in your budget and also Xperia S will get a price cut by then and it will also fall in your budget.
Apart from that I recommend you to get Note or One X, i know you have to increase your budget for that but when you are spending such a huge amount why not spend few extra thousand bucks and get something really good and worth.HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
Sony 5.2ch Component home Entertainment System HT-M5
19-05-2012, 08:37 AM #836
I have already mentioned i am not getting one S, no sd card storage and unremovable battery is just not acceptable....
I hate xperia phones, not much support plus they lag...
Note is too big for me...
And i have already increased the budget to 26k and i too don't feel comfortable paying more than 25-26k for a phone....
Plus i dont mind flashing and after nexus; samaung's galaxy series has the best development scenario...Spoiler:
19-05-2012, 09:00 AM #837
How about Sensation for 21.9k with that you can buy 1.1k worth accessories of your own choice for free at saholic.
Its a great deal I think.HTC Incredible S | Nikon S8100 | Sony VAIO VPCEG25EN | Macbook Pro 13"|
19-05-2012, 02:29 PM #838
If you are to get a new one then I'd say HOX. If I were to buy a GSII, i.e- a year old phone, I'd have definitely searched for a good second hand deal. They will save you at least 6-7 k.
Still if you wait till Mid June, SII price will fall more because SIII will be available by then. But then again, there is no point in buying a year old phone, not new anyway.♦ i7 950 ♦ SABERTOOTH X58 ♦ GTX580 ♦ 8GB RAM ♦ TX650 ♦ CM 690II ♦
24-05-2012, 10:04 PM #839In The Zone
- Join Date
- Dec 2011
- Posts
- 478
i just used flashlight app in SGS2 for an hour with LED Flash, it only consumed 30% of battery. With full recharge 3 Hours of LED Flash wud be gr8, Flash is pretty bright, can light up an entire room. Can be a great asset if there is power cut even for hours together.
29-05-2012, 07:58 PM #840Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 9
Guys, i am planning to buy the S2 in the next few days .. ..
Should i just go for it or is there any other phone better then it .. in that range ( 26k max ) ... nd is s2 being shipped with the ICS now ??
Samsung Galaxy S2 GT-I9100 vs. GT-I9100G Ultimate Comparison Guide. All You Need to Know! | 10Division.com
Refback This thread31-01-2012, 11:26 PM -
18-07-2011, 01:37 AM
06-06-2011, 03:48 PM
Samsung Galaxy S2 powered with a dual core 1.2Ghz processor launched. - Page 83 - xda-developers
Refback This thread23-05-2011, 08:21 PM -
09-05-2011, 09:16 PM
[For Sale] Samsung Galaxy GT I5510 (Galaxy 551)
By rakeshishere in forum BazaarReplies: 7Last Post: 04-05-2012, 07:46 PM -
Samsung UK confirms Ice Cream Sandwich update for Samsung Galaxy S II
By socrates in forum Mobiles and TabletsReplies: 2Last Post: 19-11-2011, 01:38 PM -
Samsung S8530 Wave II Or The Samsung Galaxy Ace S5830
By ThinkGeek@@ in forum Mobiles and TabletsReplies: 26Last Post: 05-04-2011, 09:53 AM -
Samsung Galaxy S II and Galaxy Tab II confirmed for MWC
By pauldmps in forum Technology NewsReplies: 4Last Post: 13-02-2011, 05:48 PM
LinkBack URL
About LinkBacks
