Page 24 of 30 FirstFirst ... 4 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 LastLast
Results 691 to 720 of 880
  1. #691
    Wise Old Owl ajayritik's Avatar
    Aug 2007
    Hyderabad
    Default Re: Samsung Galaxy S II
    Quote Originally Posted by red dragon View Post
    Is the item shipped?If not,give them a call and cancel the order.
    By the way I could not find any i9100G in sulekha.
    Talk to them over phone asap.
    If it's not the G one then why should I cancel?
  2. #692
    Master troll red dragon's Avatar
    Jan 2009
    Then you dont.
    A TE member got the I9100 another I9100G both from sulekha.
    Macbook Air 11"2011,Iphone 4S 16GB,Ipad2,Sennheiser HD-25 1-II,HD650,FiiO(E11,E17...yeh! I know!I need an upgrade)
  3. #693
    In The Zone dharmil007's Avatar
    May 2010
    Galaxy S2.On jkay`s simple and clean ROM V2,Speedmod kernel.
    Hey how is the ROM & KERNEL ???
    'coz i installed siyah kernel & my battery life is worst.
    i m looking for a rom & kernel that will increase my battery life & give an overhaul to my UI & add few new features.
    is it possible to install another kernel over this siyah kernel ???
    PHENOM II X6 @ 2.8GHz || GA-880GM-UD2H || Kingston 3x2GB Dual-Channel DDR3 || 1TB WD BLACK || Logitech MX518 || Samsung 20" LED SA20A300N
    ACER ASPIRE v5-431
    SAMSUNG GALAXY S2
    SignUp & Get 2GB Cloud Storage FREE !! http://goo.gl/05gWw
  4. #694
    Mozilla Rep sygeek's Avatar
    Apr 2011
    Lucknow
    Quote Originally Posted by ajayritik View Post
    lol bro, check your phone's version.
  5. #695
    Jan 2009
    Quote Originally Posted by dharmil007 View Post
    It was ok.I am back on checkrom hd with siyah 2.2 again.
    No problem with siyah for now.
    Yes you can install another kernel over it.
    Clear cache in CWM as usual.
    I am not into themes;so can not help with that.
    How is the gingermod ROM?
    Is it AOSP?I could not understand from the xda thread.
  6. #696
    Aug 2007
    Hyderabad
    Quote Originally Posted by sygeek View Post
    Bro you were the first one to kind of console me saying it wouldn't matter that much and now you say that I need to check the version after the product arrives then I can't return it back right.
    You also mentioned that in Sulekha there was a comment can you give the details.
  7. #697
    Jan 2009
    Why don't you just give them a call.
  8. #698
    Aug 2007
    Hyderabad
    ^^ They said they don't work on Saturday and Sunday.
    Is the other model so bad that I should cancel.
    Do you want me to call and cancel the product.
  9. #699
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    It isn't bad at all - at most ~10% slower in synthetic benchmarks. Real world performance is going to be the same. Much of a non-issue imho.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  10. #700
    Aug 2007
    Hyderabad
    ico and other as mentioned earlier this will be primarily used for Audio, playing video and taking photos so as long as these things are not effected I don't mind.
  11. #701
    Jan 2009
    Plus the battery lasts longer in it.
    Only problem is it does not have much Dev support at xda.
  12. #702
    Aug 2007
    Hyderabad
    For normal users this G model should be fine right? If someone is not doing rooting etc this shouldnt be a concern right?
  13. #703
    Apr 2011
    Lucknow
    Yes, it'll run fine. I don't even think that rooting will be a problem.
  14. #704
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    These are not affected at all.
  15. #705
    May 2010
    I was wondering if anyone has tried this extended battery for the SGS-2 !!
    Genuine Samsung Extended Battery Kit for Galaxy S2 - 2000mAh - EB-K1A2EBEGSTD - YouTube
  16. #706
    Jan 2009
    It is not available in India.
  17. #707
    May 2010
    Yes, Even I checked with Samsung Customer Service guys, It is not available in India, Sad though!!
  18. #708
    Aug 2007
    Hyderabad
    I'm keeping my fingers crossed bro. Don't know which model I will receive finally.
  19. #709
    May 2010
    Quote Originally Posted by sriharsha_madineni View Post
    Set Auto-brightness to off, reduce the brightness level to zero, If the yellow patch is significant, it should show up pretty much on any background, just look at the left side of screen.
    Better still, do this in a dim lit room, with a white background, if you want to be sure
    I wanna do this test, how do I bring a white background up, where will I find a white background ??
  20. #710
    Apr 2008
    Quote Originally Posted by Kvishal View Post
    One v.quick way to get near white, could be in the browser itself? Of course, if you have apps, [say widgetsoid, which has an option for flashlight, which turns the screen white].
    Answer this:
    http://www.thinkdigit.com/forum/showthread.php?t=100866
  21. #711
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    i think all android mobiles have flashlight option. just use flashlight from widget to turn your screen white.
  22. #712
    Aug 2008
    Should this make some of the Samsung Galaxy S2 owners "PROUD" !!
    Samsung Galaxy S II (The Next Big Thing) Commercial - YouTube
  23. #713
    Aug 2007
    Hyderabad
    Quote Originally Posted by pramod_kk View Post
    Be aware ! At Sulekha it is Samsung galaxy s2 GT-I9100G and not GT-I9100
    Comparison here:
    Samsung Galaxy S2 GT-I9100 vs. GT-I9100G Ultimate Comparison Guide. All You Need to Know! | 10Division.com
    Bhaiyaa pehle bol dete to acha hota.
  24. #714
    Aug 2008
    Can anyone tell me, the shooting game shown in this promo video of Samsung Galaxy S2 which game is it ? it is in the video ?
    It is just at the end of video, when the video reaches 3.18
    [Galaxy S2] Offical Live Demo-MEDIA - YouTube
  25. #715
    New Gen Guru sujoyp's Avatar
    Mar 2008
    Orangecity
    @augustya that ad was quit innovative/funny and poor apple guys waiting in line
    Photography Gears -
    Nikon D3100+18-55+55-200+50mm+55mmMicro,Tamron 17-50mmf2.8 Lowepro pro Runner 200 AW
    Yougnou YN-465 flash , Vanguard ESPOD 203AP, YN603-N3 flash trigger
    My flicker link -> http://www.flickr.com/photos/34748095@N07/
    Samsung Omnia W with Sony MDR-ED12,Micromax Funbook & Samsung 550P-S05
  26. #716
    Aug 2007
    Hyderabad
    kya sujoy bahut din ke baad. Kaisa hai tu?
  27. #717
    Dev dreatica's Avatar
    Oct 2010
    Few of my friends purchased from sulekha, and it was G model.
  28. #718
    Aug 2007
    Hyderabad
    One final time, guys do you think the G Model has too many or too major differences to reconsider trying returning it back?
    Day by day I'm getting worried about this G model. Rather than the excitement it looks like some suspense waiting to get unveiled.
  29. #719
    In Pursuit of "Happyness" kalpik's Avatar
    May 2005
    New Delhi
    If you will mod your phone (which you should, since you're getting an Android phone), you should try to return it. If you're not bothered about modding, G won't make much of a difference.
    Personally, I would not get the G, and if it's only G that's available, I'd wait for another phone.
  30. #720
    Aug 2007
    Hyderabad
    Quote Originally Posted by kalpik View Post
    I have no idea what modding is so I guess this should not make a difference.
  1. [For Sale] Samsung Galaxy GT I5510 (Galaxy 551)
    By rakeshishere in forum Bazaar
    Last Post: 04-05-2012, 07:46 PM
  2. Replies: 2
    Last Post: 19-11-2011, 01:38 PM
  3. Samsung S8530 Wave II Or The Samsung Galaxy Ace S5830
    By ThinkGeek@@ in forum Mobiles and Tablets
    Last Post: 05-04-2011, 09:53 AM
  4. Samsung Galaxy S II and Galaxy Tab II confirmed for MWC
    By pauldmps in forum Technology News
    Last Post: 13-02-2011, 05:48 PM
