Old 12-03-2011, 06:53 PM   #1 (permalink)
avichandana20000's Avatar
Default nokia 5230
does nokia 5230 support Adobe flah player?
if yes , how to download and install it?
does frequent FACTORY SETTING do any harm to mobiles?
NZXT PHANTOM WHITE|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1TB|LOGITECH G110|APC 650 VA|
avichandana20000 is offline   Reply With Quote
Old 12-03-2011, 07:02 PM   #2 (permalink)
Default Re: nokia 5230
Yes, Flash Lite only
It is already installed
No
pauldmps is offline   Reply With Quote
Old 12-03-2011, 07:23 PM   #3 (permalink)
No
sorry to say i am not able to find it out. can u help me pls?
Old 12-03-2011, 07:34 PM   #4 (permalink)
Why do you need to find it out ? Just open any page with Flash content in your browser (YouTube, for example) & it should play fine.
Old 12-03-2011, 07:41 PM   #5 (permalink)
Then let me tell you the story:
you tube videos are playing good.
but when i have opened ESPN STAR to watch live cricket. the page where STREAMING should occur it is showing a small F sign which resembles the FLASY PLAYER LOGO. ( i have vodafone promo attached for net.)
That is why i am assuming that my flash player is not working prpoerly. does that site requires any kind of subscription to view the streaming stuff?
Old 12-03-2011, 07:47 PM   #6 (permalink)
TechFanatic
sparx's Avatar
I use 5233. Flash lite is pre installed you dont have to see it. But I was too not able to play flash video other than in youtube.
sparx is offline   Reply With Quote
Old 12-03-2011, 09:23 PM   #7 (permalink)
That is a handset limitation. Try using Opera Mini if that works. Else nothing can be done.
Old 13-03-2011, 01:23 AM   #8 (permalink)
maybe its a limitation of Flash Lite.
Sam is offline   Reply With Quote
Old 13-03-2011, 09:34 AM   #9 (permalink)
That site u mentioned require flash player 9, 10. Flash lite only support flash content optimized for mobile browser using flash lite.
vishurocks is offline   Reply With Quote
Old 13-03-2011, 09:40 AM   #10 (permalink)
Manchester United <3
Ishu Gupta's Avatar
WHS
@paul
OperaMini will send you to the default browser when you run flash or download.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 13-03-2011, 09:50 AM   #11 (permalink)
^^ Yes but it directs from their servers so I thought that it might work.
Also isn't there Skyfire browser for Symbian ?
Old 13-03-2011, 10:55 AM   #12 (permalink)
Peak Oil is real!
AndroidFan's Avatar
^^ Skyfire beta is available for Symbian S60
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 17-03-2011, 07:33 PM   #13 (permalink)
i dropped my nokia 5230 in water
now it's CPU and Boot IC's are completely gone.
where i can find a genuine nokia 5230 replacement for these and a PCB for the same.
bhushan is offline   Reply With Quote
