Old 08-08-2005, 11:42 PM   #1 (permalink)
Default Antivirus no uninstalling
Hi guys
i recently installed Trend MIcro Mobile security antivirus on nokia 6600 . By mistake i installed it in the phone memory . But now whenever i try to delete it , it says " Application open " . Can anyone suggest how to uninstall it.
mako_123 is offline
Old 09-08-2005, 02:25 AM   #2 (permalink)
simple the antivirus software runs when the phone starts try to go into the software through the options and disable the software or stop the software then go to the filemanager and uninstall the application if this does not work u should definatelly try the master rest.
Any Question can be answered
fact_speaks is offline
Old 09-08-2005, 10:37 AM   #3 (permalink)
Tried but it did not help . If i try Master Reset will it erase all the data on phonne and mem card.
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 10-08-2005, 01:21 PM   #4 (permalink)
mariner's Avatar
install a file manager. the best one is fexplorer. now navigate thru this explorer and delete the program.
cant find fexplorer then pm me.
mariner is offline
