05-03-2011, 08:59 PM
Just Do It
Samsung Kies to connect to the Internet
Has anyone tried connecting Samsung Kies to connect to the Internet using the Tethering option via data cable ?
05-03-2011, 09:22 PM
Re: Samsung Kies to connect to the Internet
Yes it works.
But Kies is a horribly buggy software. It is better to use Windows dialup instead.
06-03-2011, 03:35 PM
Just Do It
Originally Posted by pauldmps
Yes it works.
Please tell me how I setup and do it, for Kies and Windows dialup [ I have Dataone Broadband ].
06-03-2011, 04:27 PM
Install phone suite, connect phone and click connect to internet. There should be an option in Kies.
06-03-2011, 05:39 PM
Just Do It
That is the Tethering option in Kies to connect to the Internet. But it gives me a message about OS Error.
06-03-2011, 07:07 PM
For Windows dialup:
Open device manager -> expand modems -> Right-click Samsung Mobile USB Modem -> select properties -> click Advanced -> paste this in the Extra initialization commands box
AT+CGDCONT=1,"IP","TATA.DOCOMO.INTERNET"
(Replace TATA.DOCOMO.INTERNET with the access point of your network in case it is not Tata Docomo)
Click- OK -> Create a dialup connection using control panel -> put phone number as *99# -> leave username & password blank & connect. In case this does not work, put your mobile no. in both username & password boxes.
06-03-2011, 10:45 PM
Just Do It
Attached screenshot shows an error message.
Please help.
For Windows dialup:
Click-OK -> Create a dialup connection using control panel -> put phone number as *99# -> leave username & password blank & connect. In case this does not work, put your mobile no. in both username & password boxes.
06-03-2011, 10:48 PM
Are you using the right access point ? Which network are you on ? Also did you try putting your mobile no. in both username & password fields ?
07-03-2011, 03:13 PM
Just Do It
1. I've entered this
AT+CGDCONT=1,"IP","BSNL.DATAONE.INTERNET"
2. I don't understand what you meant by network. If it's the internet connection, then BSNL Dataone Broadband
3. I tried it with *99# first, it didn't work and then entered mobile number in username and password. It shows that error.
07-03-2011, 05:12 PM
BSNL Dataone Broadband ?  Are you connecting from your mobile phone or via landline ?
07-03-2011, 05:16 PM
Just Do It
Yes Dataone Broadband
Connecting from mobile phone via Data Cable[USB].
07-03-2011, 05:19 PM
You are totally confusing me. Internet from mobile is not called Broadband. It is called GPRS (or 3G).
And it seems that your access point is wrong.
07-03-2011, 05:20 PM
well, he can name it anything he wants. Only thing which matters is that he has the right device linked to the connection.
07-03-2011, 05:21 PM
Use "bsnlnet" (without the quotes)
Just Do It
Oh ok, I am connecting the broadband from Landline. Please tell me what the access point should be ?
07-03-2011, 05:22 PM
Wouldn't it be weird to call a 30 kBps connection as Broadband ?
07-03-2011, 05:23 PM
Just Do It
Ok, please tell me how.
07-03-2011, 05:26 PM
OMFG!       :sh ock:
Then what is the use of discussing about Samsung Kies ? It is meant for mobile phones & GPRS connection.
And Broadband connection does not require Access point.
Do you have a Broadband modem with you ?
07-03-2011, 05:29 PM
#19 (permalink)
I haven't used my mobile as a modem ever in Windows.
Connect your fone and I hope the phone modem drivers are installed. Go to My Network places. Then create a new connection ---> Connect to Internet ---> Dial-up connection ---> choose the device i.e. the fone modem ---> Telephone number has been mentioned above.
I think this should do it.
07-03-2011, 05:35 PM
#20 (permalink)
@ico
Read his earlier posts. Once he says that he is connecting his phone & once he says that he is connecting his landline. What exactly is he doing ATM?
07-03-2011, 05:36 PM
#21 (permalink)
Just Do It
Yes, Dataone is connected to the broadband modem
07-03-2011, 05:40 PM
#22 (permalink)
I will request you to clarify what you want to do .
30-12-2011, 06:04 PM
#23 (permalink)
For Windows dialup:
Hey I am unable to get Samsung USB Modem in my device manager. PLs help me!!!!!
05-02-2012, 08:09 PM
#24 (permalink)
where is the device manager in samsung kies to start on with internet ?
03-03-2012, 06:36 PM
#25 (permalink)
Connect your mobile to PC and then enable USB tethering in your mobile.
(go to settings -> wireless and networx -> tethering and portable hotspot and enable USB tethering)
Now your mobile will work as a LAN modem. And if you are connected to internet on you mobile then you will automatically be able to use internet on your PC without making any dial-up connection etc.
