Originally Posted by Gollum
I bought I ball card reader for 350 last week. it looks like a flash drive and reads all kind of cards and is usb 2
this one?
iBall CR261 Card Reader with 54 types of Memory cards support. Interface: USB 2.0
Memory Cards Supported: SD, MINI SD, HS MINI SD, MINI-SD Ultra II, MINI-SD Ultra II Mobile, EXTREME SD, EXTREME III SD, ULTRA II SD, SD-ULTRA-X, ULTRA SPEED SD, SD PRO, SD ELITE PRO, HS SD, SDHC, Micro SD, T-Flash, Micro SD HC, T-Flash HC, Micro-SD Ultra II, MMC, MMC-I, MMC-II, MMC Dual Voltage, MMC 4.0, HS MMC, HS RS MMC, RS MMC, RS MMC 4.0, DV-RS MMC, MMC MOBILE, MMC Micro, SDXC, MS, MS PRO, MS PRO ULTRA II, MS DUO, MS PRO DUO, MS PRO DUO ULTRA II, MS MG PRO, MS MG, MS MG DUO, MS MG PRO DUO, EXTREME MS PRO, EXTREME III MS PRO, ULTRA II MS PRO, HS MS MG PRO, HS MS MG PRO DUO, HS MS PRO, HS MS PRO DUO, MS ROM, MS SELECT, MS Pro HG, MS Pro HG Duo, M2.
its nice card reader but actually for mobile small size cards. (Read Mini and Micro SD cards directly without any adapter)
this card reader not for. Smart media, Compact Flash, etc big size memory cards.
Originally Posted by thetechfreak
Congrats @Rockstar11
what kind of speeds you getting?
if you use Win xp, then use software called Tera Copy for a speed boost.
In Win 7, dont use 3rd party software.
Interface : USB 2.0
Smart Media card speed test.
Write speed : 1.61 MB/Sec
Read Speed : 6.21 MB/Sec
speed test using USBDeview v1.75 software.
i am using win xp.
hmm.. tera copy. ok
thanks
