Re: SDHC card is not detecting in Samsung Galaxy 551
Your card might be password protected. Nokia is notorious for password protecting memory cards without user interaction (it happened to me & many of my friends).
Insert the card back into your Nokia (the same phone) check in options. If it shows options to "remove password" & "change password" alongwith "format memory card", you're card is locked.
Unfortunately, you cannot do anything about it. I still haven't found any meas of unlocking the card. I don't know the password because I haven't locked it.
