Old 02-03-2011, 11:02 PM   #1 (permalink)
pushkaraj's Avatar
Default MicroSDHC for Optimus One
Hi guys,
I recently bought the Optimus One and now wish to go for 16 GB microsd card. I wish to know if class 10 cards are available and if yes, how much would they cost. If the price difference is huge, then i will have to settle for a class 6. Also, which of these brands should i opt for: Sandisk, Kingston, Transcend?
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline   Reply With Quote
Old 02-03-2011, 11:22 PM   #2 (permalink)
Dev
dreatica's Avatar
Default Re: MicroSDHC for Optimus One
Originally Posted by pushkaraj View Post
Hi guys,
Class 10 are not available easily, and they are costlier too. Go for 16gb class 4/6 which ever is available. I never cared about brands, got one kingston through ebay which is working well.
dreatica is offline   Reply With Quote
Old 03-03-2011, 01:16 AM   #3 (permalink)
^^ what is the rate for such card of 4Gb capacity?
Sam is offline   Reply With Quote
Old 04-03-2011, 02:50 AM   #4 (permalink)
Dev
dreatica's Avatar
you asking about class 6/10 ? I am not sure about those.
I bought a class 4 card 4gb for 400rs if I remember . 8gb class 4 for 695 through ebay and 16gb class 4 for 1,550rs locally. Kingston/sandisk etc- they all fall in same price but I prefer kingston.
Old 04-03-2011, 08:06 PM   #5 (permalink)
pushkaraj's Avatar
Thanks for the replies guys
I think i will settle for a class 6 card. Found a Transcend one for 1.5k on ebay .. well under my budget ...
Old 30-05-2011, 02:13 PM   #6 (permalink)
what is the difference between MicroSD and MicroSDHC? will O1 support MicroSDHc
rockstarmpm is offline   Reply With Quote
Old 30-05-2011, 02:51 PM   #7 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Most probably the same thing...
Swimming is not a sport. Swimming is a way to keep from drowning. That’s just common sense!
--- George Carlin
AndroidFan is offline   Reply With Quote
Old 30-05-2011, 04:10 PM   #8 (permalink)
atin's Avatar
Dude just FYI I purchased a class 6 8 GB card (A-Data Turbo) from play-asia for 900.
You may wanna check it out.
The ladder of success is never crowded at top:Napolean
atin is offline   Reply With Quote
Old 30-05-2011, 04:28 PM   #9 (permalink)
Just get any Class 6 card or above. That'll work fine.
Old 31-05-2011, 10:55 AM   #10 (permalink)
Dev
dreatica's Avatar
Digging an old thread guys
Anyway, you can get class 6 sandisk/kingston for 500-600 bucks. Google discount and ebay
