Old 02-03-2011, 03:40 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Samsung Galaxy Ace - Should I?
So I am about to buy the Ace. I wanted the O1, but the Ace suddenly appeared at my local dealer.
The only things I'm worrying about: .avi playback and app compatibility.
Are there any issues?
AnarchyInc is offline   Reply With Quote
Old 02-03-2011, 10:15 AM   #2 (permalink)
Peak Oil is real!
AndroidFan's Avatar
Default Re: Samsung Galaxy Ace - Should I?
If you like Ace, then buy it. There are plenty of media players in the Android market which can play AVI files...
As for App compatibility... some apps might not work because of HVGA resolution... which is the same situation as in O1.
I've read on this forum that people are experiencing poor battery life with Ace and other new samsung phones...
AndroidFan is offline   Reply With Quote
Old 02-03-2011, 10:30 AM   #3 (permalink)
Only confirm the battery issue before buying the phone else everything is ok.
pauldmps is offline   Reply With Quote
Old 02-03-2011, 11:50 AM   #4 (permalink)
Simple answer, YES ...
pretty good mid range android ... u shud have no issues with app compatibility ... and *.avi files will have an upper resolution limit (which every fone does) ... but shud be fine to directly drop and play non HD movies & shows
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 (CM7 beta6.5:-D), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur detailshere
k4ce is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/137420-samsung-galaxy-ace-should-i.html
Thread internet problem in galaxy ace | Digit Forum | BoardReader This thread Refback 15-05-2011 10:11 AM
