Re: usb tethering in O1
if you do it just this once, its ok... but yes, it will harm your battery for the sole reason that your battery temp will increase ... and if a battery is operated at a higher temperature for long amounts of time, battery life goes down ... li-ion batteries dont like heat ... so avoid using it on a usual basis
Acer Aspire 5536
X2 QL-64 2.1Ghz, 2GB RAM, 320GB HDD, ATI HD 3200
LG O1 ( CM7 beta6.5:-D), PSP-Go 6.20 (TN-A Hen)
LG o1 owner ?... update ur details here
