Old 27-02-2011, 11:20 AM   #1 (permalink)
mekalodu
iinfi's Avatar
Question sync contacts between two Nokia Symbian fones
hi all..
i have an E63 and a N97 mini.
is there a software to sync contacts effectively between the two fones.
eg. if i add/update a contact in one fone it sud be replicated in the second fone and vice versa without the use of a third party software ... like ovi suite etc
mekalodu
iinfi is offline   Reply With Quote
Old 01-03-2011, 06:37 PM   #2 (permalink)
Default Re: sync contacts between two Nokia Symbian fones
Hi , the best solution is to use Ovi Suite. However you can also set up a sync profile on both phones with one ovi calendar account. This way when you sync one phone with the cloud server , it will get updated on the website and when you update the second phone , it will pull in the updates from the cloud.
Do let me know how it goes !
Anirvann is offline   Reply With Quote
Old 01-03-2011, 07:48 PM   #3 (permalink)
mekalodu
iinfi's Avatar
well i m already using ovi suite but i constantly face issues with duplicate records and sync conflicts .... i dont want to constantly keep changing the sync conflict option either ... i wont know at any point on which fone i v updated which record ... thats what i want to make it automated .....
anyway i v googled a lot and v found nothing ... thanks anywayy
mekalodu
Old 02-03-2011, 10:09 AM   #4 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
On N97 mini you can go to Menu > Tools > Sync. Turn on bluetooth of both the mobiles. I think it takes care of duplicate records.
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
